Reply
Thread Tools View Mode
Old 11th Mar 2017, 21:47   #1
AM Modding
Minimodder
AM Modding has yet to learn the way of the Dremel
Project 4: Renaissance of the Phnix
Hi everyone,
I have a small modding case going for a friend
It is called Renaissance of the Phoenix because I give life to an old tower of the years 2000. The main colors will be the gold (and derivatives) as well as the black.
It's a quick little budget mod made with what drags on the cupboards (for the case)
As for the config it will be new, i5, rx480, 8gb ram, ssd, hdd, in short the comfortable
To follow cutting, painting and mounting ...
AM Modding is offline   Reply With Quote
Old 12th Mar 2017, 00:04   #2
Vault-Tec
Banned
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
Wow a slider case ! not seen one of those in a few years. Alienware used to use the smaller model.
They were made between 1996 and 1998 after that Alienware moved to the Chieftec Dragon.
This boring fact was brought to you by Vault-Tec. Remember kids, duck and cover !
Vault-Tec is offline   Reply With Quote
Old 12th Mar 2017, 06:57   #3
AM Modding
Minimodder
Ah I did not know, thank you very much for this information, I now know that the case is older than me
Old 12th Mar 2017, 20:00   #4
AM Modding
Minimodder
First cut-outs at the top of the case and first tests
Old 17th Mar 2017, 20:09   #5
AM Modding
Minimodder
The equipement will be
Seagate BarraCuda 1 To
Kingston SSD UV400 120 Go
ASUS PRIME B250-PLUS
Intel Core i5-7400 (3.0 GHz)
MSI Radeon RX 480 GAMING X 4G
Thermaltake TR2 500W Gold
ASUS Cerberus Keyboard
Logitech Wireless Mouse M235 (Rouge)
Microsoft Windows 10 Famille 64 bits - OEM (DVD)
be quiet! Dark Rock 3
DeepCool RGB 360
Corsair Vengeance LPX Series Low Profile 8 Go (2x 4 Go) DDR4 2133 MHz CL13
Old 19th Mar 2017, 19:07   #6
AM Modding
Minimodder
Hop hop, we don't waste time, the following
Cutouts
Logo test
Paint test
Fail paint effect test
Final paint effect
Start of the final paint
Old 25th Mar 2017, 18:35   #7
AM Modding
Minimodder
First update of the WE, it will have a second tomorrow
Old 26th Mar 2017, 18:01   #8
AM Modding
Minimodder
Second update of the WE
Old 27th Mar 2017, 06:46   #9
storm-83
Supermodder
storm-83's Avatar
storm-83 has yet to learn the way of the Dremel
you should give him 1gb worth of storage, spread out on 48 drives(~20gigs each), because y2k...
Love me a grey mod, so will be looking forward to more updates!
__________________
storm-83 is offline   Reply With Quote
Old 27th Mar 2017, 16:26   #10
AM Modding
Minimodder
Thank you ! It Will be finished this week with an extra for you guys
Old 29th Mar 2017, 18:44   #11
AM Modding
Minimodder
Old 4th Apr 2017, 20:03   #12
AM Modding
Minimodder
3 2 1 Test [ON]
Old 15th Apr 2017, 18:36   #13
AM Modding
Minimodder
https://www.youtube.com/watch?v=GOzfbZli6vE
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
