Reply
Thread Tools View Mode
Old 14th Mar 2017, 20:17   #1
PaYFrog
What's a Dremel?
PaYFrog has yet to learn the way of the Dremel
Enermax Steelwing - The Pinkwing
Dear PC fans and enthusiasts,
I want to introduce a new mod. The Case will get the wings you can notice in the name but donīt see at the case. One of the new wings will be used for the reservoir and cooling loop. The power supply will be moved and customized a little bit. This will be done secretly, the final changes will be postet after finished changes.
The fans are already prepared but not finished yet. I added some adressable LEDs and wrote some programs. The first 5 modes are allready finished. A small housing for the controller exists allready and will be mounted near the 4 fans.
A 480mm or 360mm radiator will be used to cool the GPU and CPU. For the stand alone radiator the design will get close to the case.
The gpu for the Seelwing has allready arrived. The FE coolers are still a beauty. The colour concept of builds should be seen good here.
The Sleeve is here for some time. The colour is simply the best, sometimes it should be something else.
The rear of the case has been replaced by a new one. The new rear holds the gpu, a connection for the PSU and pass-through for the water cooling. It will be colored with the rest of the components later.
The threaded rods from the motherboard tray I donīt need are all knocked out. The motherboard tray will also cleaned later.
Thats all informations I actually have. Tomorrow there will be a nice package hopefully. Then I will post another special thing for this build. I hope you like it.
Greets,
PaYFrog
PaYFrog is offline   Reply With Quote
Old 17th Mar 2017, 19:37   #2
PaYFrog
What's a Dremel?
One step further. The Motherboard for the steel wing has arrived. I will use a MSI Z270I Gaming Pro Carbon AC.
The will hold an i7 7700k from Intel. To storage all data I will use a Crucial MX300 M.2 SSD with 525GB.
For the photos I got some RAM form the pcs of my friends. Which version do you like most?
Old 23rd Mar 2017, 21:01   #3
PaYFrog
What's a Dremel?
Last time I asked on facebook wich RAM would fit best for the MSI board in poeples opinion. The result was pretty clear and also in line with my ideas.
I ordered the G.Skill TridentZ RGB DDR4 2x8Gb 3000 MHz. Why RGB? Somehow I have to light the RAMs pink.
The sidepanel is already assembled. If it pass the tests, you will see some photos pretty soon.
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
