Reply
Thread Tools View Mode
Old 17th Mar 2017, 19:26   #1
PaYFrog
What's a Dremel?
PaYFrog has yet to learn the way of the Dremel
Thermaltake Core x9 - "White Memorie"
Dear PC enthusiasts,
today I want to introduce to you my second Thermaltake Core x9 build. This time I want to do something other than last time. I allready made some changes, so you can still see the concept.
Basement:
Concept:
The case will be seperated horizontaly. The lower part of the case will be holding two 480mm/60mm radiators. The new cover on each side of the case will hold one of them. Behind the front I will add an HDD/SSD cage, so you can mount them easily. The PSU will get a new position in the upper of the case. Mounted right behind the front, you got a great view on the PSU and the cables. Next to it I will mount the reservoir and go straight to the midplate into the lower section of the case. To get a good view all over the case I will install acrylic plates in the top and both sides.
The sidepanels for the lower part of the case are finished. In fact of missing fans I mounted the radiators without them. The pump is allready mounted at the final position. The HDD cage is integrated in the front of the case.
I hope you like it.
PaYFrog is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
