Reply
Thread Tools View Mode
Old 18th Mar 2017, 15:53   #1
WanV
Minimodder
WanV has yet to learn the way of the Dremel
Project Honor[Complete]
Hi,This is my second case mod
For this time i try to mod based on For Honor Games
Before That i would really like to thank you to all those sponsor and trust for my case mod and first sponsored project
Thermaltake = http://www.thermaltakeusa.com/
ADATA =http://www.adata.com
XPG From ADATA =http://www.xpg.com/en/
Here the Spec For This Case Mod
Thermaltake:
Core X71
P1 Pacific Black Pump
Pacific Flow Indicator
R240 Radiator
Pacific W3 Water Block
Pacific V-GTX10 Series
TT Sleeve Mod Cable Pack
Commander F6 RGB
Toughpower Grand RGB Series 750
TT PREMIUM FAN 3 PACK RGB
V Tubler PETG TUBE 16mm
Thermaltake Bending KIt
Thermaltake Yellow And Black Coolant
Some TT Fitting 90 Degree Dual OD,Compression Fitting,Angle Fitting,And Extender
From Adata
XPG Z1 DDR4 3000MHZ 16GB KIT
SU800 AND XPG930 SSD
Other parts
Intel Core i7 7700K
Asrock H270 Performance
Design
i've never been good for 3d such as sketchup or anything like that so i can only my design by my work in real life
Thanks
WanV is offline   Reply With Quote
Old 19th Mar 2017, 17:53   #2
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
GeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming Saiyan
Hello and welcome to the forums
Can you please edit your first post to resize your images (hit the edit button at the bottom of the first post). When using imgur you need to select the large thumbnail option otherwise your pictures show full size as our forum does not resize images for you.
Thanks
GK
GeorgeK is offline   Reply With Quote
Old 20th Mar 2017, 12:30   #3
WanV
Minimodder
Thanks
GK
hi sorry for inconvenience will do ASAP
Old 20th Mar 2017, 12:42   #4
WanV
Minimodder
my first work is measuring case size for side,front and motherboard tray since i try to custom all the part
core x71 i think can fit 420 rad but im going to use 240 rad only
measuring top panel thinking to create custom top with acrylic material
i think im going to let it maintain with stock look for back io panel
since i dont want to risk any motherboard im using biostar tpower i45 motherboard to measure tray and offset for my part
i think can fit 2 330ml reservoir but im going to use 220 res only
Old 21st Mar 2017, 12:25   #5
WanV
Minimodder
Front Panel part which i cut with laser cut machine
Done cut with laser and now assembly some part to see which 1 missing
top panel which i trace with laser and need to remove 1 by 1 before spray
Old 21st Mar 2017, 12:27   #6
WanV
Minimodder
remove all standard fan which came with x71
front panel switch button,its easy to remove only 2 screw used to mount it
cutting front panel because i will fully custom with it only need the frame
Old 22nd Mar 2017, 03:18   #7
WanV
Minimodder
sanding frame and side panel with orbital sanding 320grit
wet sanding with 800 grit to get smoother finish
using tack cloth to remove all dust,oil
Old 22nd Mar 2017, 03:20   #8
WanV
Minimodder
Case Mod Project Honor[COMPLETE]
ready my acrylic part
my spray gear and paint
using alloy red paint
Old 22nd Mar 2017, 03:23   #9
WanV
Minimodder
undercoat silver to get the colour right
thinning the paint to 2:1 ratio with thinner
Undercoat Process for all part
Frame
Side Panel 1
Bottom Panel/Rad Panel
Pcie Slot
Front Panel Acrylic
Old 22nd Mar 2017, 10:35   #10
WanV
Minimodder
done spray red alloy colour for frame
not really good finishing i hope i got a room for spray
front panel part
pcie slot with pearl gold
Old 31st Mar 2017, 04:37   #11
WanV
Minimodder
Finish Part
Top part
Front Panel
now i start to knit front panel with hemp cord
slowly progress
half done
done tighten all rope
Old 31st Mar 2017, 05:00   #12
WanV
Minimodder
Done front panel
inside front panel
inside ssd box
Old 1st Apr 2017, 13:04   #13
WanV
Minimodder
Thank to asrock for this nice motherboard
H270 performance
it look fancy eventhough its just H series
Old 5th Apr 2017, 03:54   #14
WanV
Minimodder
my custom reservoir stand based on samurai sword stand
Old 5th Apr 2017, 04:12   #15
Evolutionsic
Gives credit where its due
Evolutionsic's Avatar
Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.
Love this! keep it up!
__________________
Loose lips sink ships
Evolutionsic is online now   Reply With Quote
Old 5th Apr 2017, 10:14   #16
WanV
Minimodder
thanks, by the end of next week i hope can finish this build
Old 9th Apr 2017, 09:12   #17
WanV
Minimodder
start doing wc stuff
going to place pump at top instead bottom part
done assembly thermaltake w3 cpu waterblock and i can see from this image that somepart got bad mark since im using glue to fix it
some tt fitting still thinking which way should i do
drilling 4 hole for radiator loop
quite tight spot to get good bend eventhough i can use soft tubing but i go hard tubing all the way
done fitting 2 radiator for both way
will be using tt flow indicator..i just hope tt got transparent flow indicator because when mix with dark colour coolant i cant see the flow anymore
loop to go to radiator
done doing my loop.now im going to leak test for 2-3 hours
Old 10th Apr 2017, 03:33   #18
WanV
Minimodder
Im done with my build i hope all of you can give honest opinion for my case mod
sponsor for my case mod XPG by adata,Asrock,Thermaltake
Old 11th Apr 2017, 08:12   #19
WanV
Minimodder
Top Panel
Interior
Radiator Cover
Old 11th Apr 2017, 08:14   #20
WanV
Minimodder
Temp Reader with power button
SSD Box
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
