Case Mod - In Progress Airbender
Discussion in 'Project Logs' started by @nton, 4 Jul 2011.
  1. @nton
    @nton What's a Dremel?
    3 Jul 2011
    airbender mod
    My name is Anton, and im located in the netherlands.
    I started building a system meant for shooter games and decided to call this project '(the last) Airbender' cause 1: its proberly the last time im going to realize an idea that involves this much of work and 2: i wanted to do something with airflow in mind.
    I had an Lian Li V1000 case lying around that i used for another (obsolete) system, decided to strip it and start from there.
    :dremel: Cutting up the case to fit a Coolermaster 700 W PSU:
    :dremel: Cutting up an old fan to make a custom fan grill:
    :dremel: Cutting a piece of aluminum tube for the fan guard:
    :dremel: And cutting off a part of an electric motor:
    Looks cool enough.
    Using springs to fit the ring to the fan guard:
    Fitted a Coolermaster Silent Fan:
    :D Exit Fan finished.
    This System will be based around:
    EVGA P55 F T W mainboard
    Intel® Core™ i7-870 CPU
    Geil 8 GB DDR3-1333 EVO ONE memory
    2 Asus EAH6850 DirectCU/2DIS/1GD5 Videocards in crossfire mode
    1 OCZ SSDPX-1RVD0080 GB PCIe x4 RevoDrive
    Some pics of the hardware:
    Installing the CPU, cooler and memory
    Added the OCZ 80 GB RevoDrive for fast bootup.
    :idea:
    lower Air Intake
    The Lian-Li V1000 has 2 compartements, the lower part of the case has an intake fan but
    since the air is not going anywhere except cooling harddrives that aren't there, it did not
    really make any sense to keep the HD racks.
    :dremel: So i cut them out and thought of something that feeds air to the CPU in the upper compartement. I removed the stock fan and used PVC tubes and various plastic parts i found in a local hardware store, and fitted a fan and an airhorn i had lying around.
    Wet sprayed the parts black, and installed them:
    :idea:
    I had a big gap to fill up front so i was thinking of a second fan, i came up with the idea of a jet engine thats looks somewhat like this:
    :dremel: So i looked for parts i could use in various hardware stores, and started building a jet engine from scratch using aluminum air duct parts, PVC, and a Aerocool turbine fan.
    Found an old CPU cooler i can use:
    :idea:
    Used part of a led lamp:
    For the rear cone.
    :dremel: Cutting up a tin can:
    :idea:
    Installed a orange CCFL for exhaust lightning effect:
    :D Rear part finished:
    :dremel: Cutting up PVC for the front part:
    Shaping it somewhat curved:
    :dremel: I can use this!
    :dremel: Fitting the turbine fan:
    :D Taking shape:
    Wet sprayed black:
    :D Lightning effect:
    Up next: Adding engine detail:
  2. KiiYzOo
    KiiYzOo What's a Dremel?
    11 Mar 2011
    wow awesome ideas :eek:
    love the evga p55 board never seen pics of it other than on the evga website :)
    subbed :D
  3. Shael
    Shael What's a Dremel?
    19 Jan 2011
    Very, very cool intake fan mod :thumb" maybe you should mount on the side of the case for something different? :D Subbed
  4. Jipa
    5 Feb 2004
    This looks absolutely superb! I may actually have to try something similar just for decorative use :lol: But I do also think that the lower intake isn't going to do anything, axial fans generate barely any pressure, so no air is going to travel through that narrow pipe. If you want the tube to work, you should use a radial- or blower fan to push air through it... With your skills it shouldn't be hard to make that look good as well :)
    xMathiasD likes this.
  5. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    :jawdrop: :jawdrop: :jawdrop: :jawdrop:
    ... ZOMG that's beautiful. Nice skillz there, I'm jealous :lol:. I'm following this closely.
    Keep the great work :thumb:
  6. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    Modding in it's purest form! :thumb:
  7. jeckulz
    jeckulz What's a Dremel?
    18 Jan 2011
    AWESOME jet engine mate. When you built that rear fan thing at the start, I was like "WTF?"
    But then you built the front up and I was like "Aaaaw, yeaaaah"
    Youve got the same GPU as me, only you have xfire, I was thinking about xfire as theyre good value for the money.
    Can you give me the frame rates for BFBC2 @ 1920x1080? :D
  8. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    That jet engine is purely stunning and that part alone is probably one of the best mods on here.. And there is A LOT of good mods on here, and using one of those old fan ccfl's for the engine light.. pure genius.
  9. sparkyboy22
    sparkyboy22 Web Tinkerer
    3 May 2010
    I am loving the crazy fans but do something about those power cables!
  10. bboybaker
    bboybaker What's a Dremel?
    27 Jun 2011
    Cool so far, waiting to see more updates soon:thumb:
  11. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Your creativity is beyond of this world. My friend you are a true modder. +rep and mod on buddy! :)
  12. bagman
    bagman Minimodder
    18 Apr 2009
    WOW you have amazing craftsmanship skills.
  13. jamsand
    jamsand Minimodder
    21 May 2011
    Very resourcful Loving the creative eye used to turn very day things into a frakin jet engine! lol look forward to the end
  14. @nton
    3 Jul 2011
    thx!
  15. @nton
    3 Jul 2011
    Thx:thumb:
    True! a more powefull fan has been ordered;)
    have to keep the noise factor in mind though
  16. @nton
    3 Jul 2011
    Thx 4 the positive feedback:) updates follow soon
  17. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Casemodding in its most raw and beautiful form!
    Great work man, i will have an eye on this for sure! That turbine looks WICKED awsome, and the intake idea for the cpu cooler is very original too!
  18. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    have to make some negative... cant see ur pictures seems you exeeded your bandwdht on pb... >.<
  19. TARIKK
    TARIKK Minimodder
    19 Feb 2009
    I can see them, :worried:
    Uuups, now I can't see them as well... :(
  20. @nton
    3 Jul 2011
    looking up another place to store the pics:rolleyes:
