Watercooling New WC build - Advice on temps part 2
Discussion in 'Hardware' started by bdigital, 9 Aug 2011.
  1. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Hey all,
    Since my last thread on temperatures, my system has changed due to some serious bad luck :( - So I have started a new thread to clear things up and hopefully get some advice from you all.
    Do you think these CPU temps are a little high for an i7 -950 @ 3.6GHz (HT Off)? with 1.216v. The following is a temperature test I ran, and the steps are in chronological order/sequance
    I have now installed 3x Sytche GT 1850s to the triple and re-run my tests - These have been labelled as Test 2 and are written in red below. Overall looks like about a 5c reduction. hmmm
    Test 1 - 13:09 Idle (from cold boot) - 34/35c
    Test 2 - 18:05 Idle (from cold boot) - 35/36c
    13:19 Idle after 10 mins - 39/40c
    Test 2 - 18:15 Idle after 10 mins - 37/38c
    GPU 30c
    13:29 Idle after 20mins - 42/43c
    Test 2 - 18:25 Idle after 20 mins - 38/39c
    GPU 30c
    13:43 idle after 34 mins - 43/44c
    Test 2 - 18:40 Idle after 35 mins - 39/40c
    GPU 30c
    13:49 Switch on Prime 95 (instantly jumps to) 56/57c
    Test 2 - 18:46 Switch on Prime 95 (instantly jumps to) - 52/53c
    GPU 30c
    13:54 Prime 95 (after 5mins) 59/60c
    Test 2 - 18:51 Prime 95 (after 5 mins) - 54/55c
    GPU 32c
    14:04 Prime 95 (after 15mins) 61/62c
    Test 2 - 19:00 Prime 95 (after 15 mins) - 56/57c
    GPU 33c
    14:13 Switch on furmark (while leaving Prime 95 running):
    GPU jumps to 59c instantly
    CPU to 64c
    19:07 Switch on furmark (while leaving Prime 95 running):
    Test 2 - GPU jumps to 52c instantly
    CPU to 57/58
    14:23 after 10mins of Furmark + Prime 95
    CPU = 71/72c
    GPU = 68c
    Test 2 - 19:17 after 10mins of Furmark + Prime 95
    CPU = 64/65
    GPU = 62c
    14:30 after 17mins of Furmark + Prime 95
    CPU = 75/76c
    GPU = 71c
    Test 2 - 19:25 after 18mins of Furmark + Prime 95
    CPU = 66/67c
    GPU = 62c
    14:30 Switch off Furmark + Prime 95
    CPU Instantly drops to 60/61c
    Test 2 - 19:27 Switch of Furmark + Prime 95
    CPU Instantly drops to 52/53
    GPU = 42.8c
    14:34 CPU idle 52/53c
    Test 2 - 19:34 CPU Idle - 42/43c
    GPU 34.3c
    This is my setup:-
    I7 950 @ 3.6GHz (HT off) Voltage @ 1.216v (in cpuz)
    3x 2gb XMS3
    GA UD5 X58
    GTX 480
    Corsair AX850
    500gb Sammy F3
    TJ07
    Loop:-
    Swiftech MCP655-B pump with EK top >> GPU (EK full cover block) >> CPU (EK Supreme HF, CU) >> Double rad (Thin) >> Dual EK Spin Res >> Triple rad (Thin)
    Fans on the triple are Sycthe Gentle Typhoons 1850s
    Fans on the double are Enermax twisters
    Any thoughts on what the problem could be would be very much appreciated.
    thank you
  2. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    Overloaded pump?
  3. bdigital
    10 Aug 2010
    Do you think maybe the pump is not man enough for the job?
  4. llamafur
    27 Jul 2009
    I'm not quite sure, it just seams like you have lots of items on one loop.
  5. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I think the rads aren't enough personally, technically you have less rad then me even though your using 2 rads. And that pump is easily enough for it, as your putting less restriction in the loop than mine.
  6. SolidShot
    SolidShot Minimodder
    8 Jul 2011
    hes got a 240 and a 360? Surely that would be more than enough? perhaps the waterblock/TIM isnt fully on?
  7. Guest-56605
    Guest-56605 Guest
    Thin radiators, depending on fin density and the fans mounted on them; in my experience pull configurations are better suited than push :thumb:
    I'd swap out the 360 for a deep rad as I assume the 240 is the roof mount?
  8. Bloody_Pete
    11 Aug 2008
    They're both the think versions, so they have max of half the capacity of a XSPC RX series rad. And that 480 & i7 kick out masses of heat...
  9. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    basically what Pete said, and that pump is more than up to the job of what you have, best pump there is in my opinion :)
  10. bdigital
    10 Aug 2010
    Your quite right. The double is in the roof.
    If i swap the triple in the bottom for a thick rad i might have to re-think the location/fitting of my pump.
  11. Guest-56605
    Guest-56605 Guest
    Small price to pay sorry to say Bobby
  12. Bloody_Pete
    11 Aug 2008
    what case is it?
  13. bdigital
    10 Aug 2010
    TJ07.
    So are we saying to replace the bottom triple with a thick rad, and then perhaps get rid of the double in the roof?
    Or keep the roof rad in?
  14. thetrashcanman
    18 Nov 2010
    480?
  15. Guest-56605
    Guest-56605 Guest
    Keep the roof rad and change the fan config to pull for that if possible and either a 360 or better still a 480 thick rad in the base would be my advice yes mate :thumb:
  16. bdigital
    10 Aug 2010
    All fans are pulling on both rads.
    Hmm okay lads. I have a look see inside the case and see how i can get things to fit.
    Im tempted to take the roof rad out to improve flow, or do we think all is ok with it in?
  17. Guest-56605
    Guest-56605 Guest
    You could do that also but then I'd definitely recommend a thick 480 in the base, a Phobya G-Changer V1.2 480mm Quad Radiator will set you back £76.59 from specialtech.
    http://www.specialtech.co.uk/spshop...ad-Radiator--G-Changer-480-V12-pid-12194.html
    I recommend both the rad itself (I have 2 x 120's in the base of my Phantom) and specialtech are excellent suppliers :thumb:
  18. Big Elf
    23 Apr 2009
    Using a rad that's double the thickness doesn't automatically double the performance, you may lose a few degrees in temps only, check out the performance of a Swiftech MCR at http://skinneelabs.com/triple-radiator-comparison-v2/4/. It would be interesting if you could find out which make and model they are. Older ones won't be as efficient as newer ones though.
    Rads don't normally have a lot of restriction unless it's one of the older Black Ice ones. I ran 2 quad rads, 2 GPU blocks and a CPU block from a 655 (setting 5) without problem.
    Check for blockages/gunk in your loop, the GPU fittings as I mentioned in my PM and whether the pump is operating properly. You'd get better cooling with higher performing fans.
    Edit: While I remember, check out the performance of the BI SR1, that's a 'thin' rad compared to an RX series but has good performance
    Edit2: Stick a thermometer in the res if you can and we can look at water temps to try and get an idea of what's going on.
  19. bdigital
    10 Aug 2010
    Right, im aiming to get a thermometer to test ambient room temps, and water temps today.
    Gpu fittings and thread info, I will re read my pm from elf and try to provide the info.
    Pump wise, I dont think you can adjust the power of this one like some of you seem to be suggesting? I think in the bios its reported to be running at circa 4000 rpm but I will check this and confirm tonight
  20. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    The MCP655-B doesn't have speed adjustment; it's hard set to the equivalent setting of "4" on the MCP655. Still an excellent pump though, should be no issue there.
