Have seen a few project logs for this and really like the case so just have a question about the potential for a radiator on the top panel. The case has a 120mm top fan slot and a 3.5" bay. Would a radiator (probably 30mm) fit underneath the fan without conflicting with the motherboard and if so, could you mount another 120mm fan where the hdd bay is to make it a 240mm? If you can then would it be possible to have 2x240mm radiators (front and top and both 30mm) without conflicting in space?
Yes almost exactly that (+rep), as there is no fan slot how much modding is required to mount a radiator at the front of the top or a 240mm all the way along?
Sorry for the late reply.. Looking at the pics I can find a 240 will go in the top but will probably cause clearance issues with the mobo/ram. As for what you say about modding. It really is a case of marking up the holes from a fan and drilling them. So very basic stuff really. I found a couple of pics with a front mounted 240 rad ( AIO type) so it looks like it will go in with out to many problems, from what I can see all the mounting holes are already in place for the fans.
