Graphics So I just baked my broken 8800GTX...
Discussion in 'Tech Support' started by Hg, 12 Apr 2010.
  1. Hg
    Hg The game known as life
    3 Aug 2007
    AND IT NOW WORKS!
    Over the last few weeks my girlfriends PC has been BSODing and getting artifcats on screen, and finally a few days ago the 8800GTX gave up the ghost and died.
    After doing a google and coming across http://forums.ninjalane.com/viewtopic.php?f=32&t=1316&start=15#p10728
    I decided to give it ago and see if baking the 8800GTX in an oven would indeed fix the issue.
    I have attached a few pics to show you what i did. As well as a easy 10 step guide to help those out who may also have a dead graphics card lying about.
    1. Removed heatsink from GPU
    2. Cleaned all thermal compound from GPU
    3. Placed foil on baking tray to make sure its a clean surface
    4. Rolled up 4 foil balls to roughly 10mm diameter
    5. Place card on top of the foil balls making sure each ball is at the corner of the card with the GPU facing up
    6. Pre-heat oven to 180c
    7. Placed GPU in oven for 10 minutes (timed on timer)
    8. Remove GPU from Oven (using oven gloves as the tray will be hot) and leave to cool over night
    9. The following morning re-seat the heatsink on the card making sure you apply thermal where you removed it, yesterday.
    10. Assemble into pc and boot and test.
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    The reason baking a GPU works is over a GPUS lifetime it is subjected to a lot of temperature change and high temperatures while gaming, this may over the years cause the soldered joints to move causing loose connections etc, by baking the GPU at around 180c your moving the solder just enough for it to flow back into place fixing those loose connections.
    I for one am very shocked that it worked but i'm also relieved that it worked, the card has now been running heaven benchmark and 3dmark 06 for almost a day without issues.....
    Hg
    dave_salmon likes this.
  2. kenco_uk
    28 Nov 2003
    NVidia are making pizzas now?!
  3. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    If you put Fermi in an oven, you could probably cook a pizza.
  4. null_x86
    null_x86 Thread Closer
    18 Jan 2009
    At least youre not the noob a few weeks back on *chan that baked theres to the point of the die falling off.
  5. Domestic_ginger
    Domestic_ginger What's a Dremel?
    16 Mar 2010
    From what I have read you managed to bake it the wrong way up. I'm still wanting to try this but unfortunately the artifacting cards are not much cheaper than a working one.
    Some bloke did it on a 4870x2 and a bit fell off (resistor). The card still worked fine though!
    Gratz!
  6. confusis
    confusis Kiwi-modder
    5 Jan 2006
    Thanks to this I just bid on an auction for faulty 8800gt, 8600gt, 8500gt and a 7900gt. At my max bid i could sell off the coolers and make most of my money back if the baking fails!
    Here's hoping
  7. Hg
    3 Aug 2007
    Hay confusis, did you have much luck with this?
    A friend of mine got his old 8800 to work again using this trick :p
  8. Ph4ZeD
    22 Jul 2009
    To be honest, if you had a faulty out of warranty card, the best start would be to remove the cooler and strip off all the old TIM, add new TIM, then remount the cooler. Then if that doesn't work, try the oven trick.
  9. Krikkit
    21 Jan 2003
    Out of interest were you guys using the stock cooler on your cards?
  10. Ant1981
    Ant1981 Minimodder
    4 Dec 2008
    So baking is preferred to just dabbing a soldering iron over the joints? :/
  11. capnPedro
    11 Apr 2007
    Firstly it would take like hours to reqork every joint by hand and secondly it's probably the BGA that's at fault and that's hidden underneath the GPU die, so you can't even get to it. Or it's the pins on the RAM or something, in which case you'd want to use a hot air rework tool instead of an iron instead.
    In fact, for SMT/SMD soldering, an iron is the last tool you want to use.
  12. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    Home made reflow machines, I like it, lol. Funnily enough, a few guys have tried this trick on their r/c speed controllers with similar success ( though physical shocks tend to be the culprit rather than repeated heating & cooling in this instance- nothing like a 30ft jump to shake a few smts lose :D ).
  13. knuck
    knuck Hate your face
    25 Jan 2002
    Tell that to a noob and he won't believe you. Even though I was the knowledgeable guy in high school no one ever believed me when I said it was possible to fix a motherboard or a videocard by cleaning it with demineralized water to remove residues after a watercooling leak
    They also would never believe the freeze trick to temporarily revive hard drives
  14. bulldogjeff
    2 Mar 2010
    \fermi and chips any 1...thats just mental...lol
  15. Danny
    Danny What's a Dremel?
    4 May 2010
    Lmao!
  16. confusis
    5 Jan 2006
    Lost the Auction for the cards... :/
  17. Dude111
    Dude111 An Awesome Dude
    7 Feb 2010
    Wow you are quite lucky my friend :)
    Some interesting things can be done if we DONT STICK TO MAINSTREAM WAYS!!
    I hope it continues working for you!!
  18. Ant1981
    Ant1981 Minimodder
    4 Dec 2008
    No it wouldn't.
  19. SuicideNeil
    17 Aug 2009
    Have you seen how many solder joints there are on a modern graphics card, and how impossibly small most of them are? You'd need God-like soldering skills and a soldering station to match...
  20. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    yep you would be there for ages
    also has anyone else tried this?
