Other Ramdom hangs on win7
Discussion in 'Hardware' started by djzic, 10 Dec 2010.
  1. djzic
    djzic Bokehlicious!
    8 Nov 2010
    I restarted my machine after having it up for 2 days and after about 15 seconds of logging in my screen went blank with white background and black stripes. I start in safe mode and everything works fine. What could this be?
  2. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    Monitor your GPU's temperature in GPU-Z or HWMonitor, see if overheating is a factor.
    Speaking of GPUs....oh dear lol.
  3. djzic
    djzic Bokehlicious!
    8 Nov 2010
    Temps are acceptable even under benchmark
  4. Marine-RX179
    Marine-RX179 What's a Dremel?
    24 May 2010
    Any chance that your i3 530 overclock is unstable? 4.5GHz is quite higher overclock, and unstable CPU overclock can crash windows and BSOD...
  5. Pete J
    Pete J Employed scum
    28 Sep 2009
    This would be my first guess as well.
    Also, you may have the wrong settings for your RAM.
  6. Siwini
    Siwini What is 4+no.5?
    14 Sep 2010
    Check your voltage settings. Hope your using some kick ass cooler for that 4.5GHz OC lol
  7. Marine-RX179
    24 May 2010
    I think you should try resetting your CPU clock back to stock speed, and see if windows still crashes. If it doesn't, then unstable OC would clearly be the cause.
  8. djzic
    djzic Bokehlicious!
    8 Nov 2010
    It's stable, and my RAM timings are actually CL7 atm, just CL9 is rated.
    I've reset everything to stock and its a graphics crash according to windows. I'm using a Titan Fenrir cooler with a scythe gentle typhoon 1850rpm and its faced upwards towards the 200mm antec big boy exhaust fan.
    It's not unstable OC i've reset everything to stock and no bsod just blank screen. Windows reports a graphics card problem (I checked in safe mode). I think it's a driver problem.
  9. padrejones2001
    padrejones2001 Puppy Love
    17 Jun 2004
    Personally, I think your graphics card bit it, but just to be on the safe side, have you tried rolling back the drivers? Or updating them?
  10. djzic
    djzic Bokehlicious!
    8 Nov 2010
    Tried upgrade and won't work in safe mode. ill try my radeon 4650. looks like i might need an rma :(
  11. padrejones2001
    17 Jun 2004
    As in the upgrade failed?
  12. docodine
    docodine killed a guy once
    10 Feb 2007
    Weren't you running OSX?
  13. djzic
    djzic Bokehlicious!
    8 Nov 2010
    The AMD package failed to detect my graphics card so it could pick the appropriate driver which meant the .exe failed, so yes.
    Dual boot cheesecake :D
    Anyway everything's fine now I put in my 4650 as well and installed the drivers while using the 4650 as the primary display device. Thank you everyone for helping :thumb:
