Motors Should I or Shouldn't I??
Discussion in 'General' started by 56K Forever, 14 May 2004.
  1. 56K Forever
    56K Forever What's a Dremel?
    5 Apr 2004
    Hey peeps,
    I'm in a small dilema, I've found a sweet Toyota Supra 3.0 Turbo for £2500 (57k on the clock), I can get insured for a fair amount but...
    What do people think of the 93 Supra's (old style), are there any major problems besides the obvious to look for?
    What do you think, should I go for it or not??? :confused:
  2. Slick13
    Slick13 What's a Dremel?
    29 Feb 2004
    Where is it cos if your in new haw in surrey then your about 5 mins away form me. I can go check it and get some ppl i know to look it over for you.
  3. westeee
    westeee What's a Dremel?
    20 Jan 2002
    £2500 sounds abit to cheap
    it could be right for the old style supras though
    the old supras do look old compared to the new ones
  4. micb
    micb Minimodder
    4 Sep 2002
    My brother and I have always had a soft spot for those old classic Supra's.
    I would do a HPI check to see of the car is dodgy.
    http://www.hpicheck.com/
    57K sounds like crazy low milage for one.
    I surpose you should check for rust, impact damage and the suspention will be pritty old so you see if that looks like it is in need to be replaced in the neer future.
  5. 56K Forever
    5 Apr 2004
    http://atsearch.autotrader.co.uk
    Ohh yeah, this baby's dropped £500, will have to do an HPI check. I live down new haw road slick :D :clap:
  6. JADS
    JADS Et arma et verba vulnerant
    27 Mar 2001
    Try this link as it doesn't show your postcode on a public forum.
  7. 56K Forever
    5 Apr 2004
    Mental note lol, always read the url before posting - Cheers JADS
