Tapatalk permission errors
Discussion in 'Feedback & Suggestions' started by hughwi, 21 Nov 2011.
  1. hughwi
    hughwi Minimodder
    23 Dec 2003
    Hey guys,
    I recently purchased tapatalk to be able to browse the forums on my iPhone, because it had become impossible to do using the normal web browser due to the tapatalk promotional message popping up on every page load, then redirecting me to the login page.
    The problem now is that on every load in the tapatalk app, I am getting a permission error, is anyone else having tapatalk problems, or knows how I might fix this? I have tried clearing the cache, but this didn't appear to make a difference.
    Thanks
    Hugh
  2. David
    7 Apr 2009
    I've seen this a few times on Tapatalk, and haven't figured a way to resolve it.
    It's a PITA but it usually clears up after a couple of hours, for me.
  3. hughwi
    hughwi Minimodder
    23 Dec 2003
    This only appears to happen on 3G signal. On wireless it works fine? - even on *wireless* on a 3G dongle/mifi?
  4. hughwi
    hughwi Minimodder
    23 Dec 2003
    Hey guys, could you check/upgrade to the latest tapatalk plugin, apparently it has fixed quite a few of these issues with 3G connectivity! Thanks hugh
  5. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    I've updated the plugin.
  6. Unicorn
    25 Jul 2006
    Is there another update available for the Plugin Jamie? I get a crash to home screen every time I select the "forum" view mode on bit-tech.
  7. hughwi
    hughwi Minimodder
    23 Dec 2003
    This appears to have fixed things for me, thanks :)
  8. Jamie
    12 Mar 2001
    We are running the latest version.
  9. Unicorn
    25 Jul 2006
    Thanks Jamie. I'm going to delete and re-install the app and see if that helps.
