Memory DDR2 Activity LED Strip - Possibly made by NZXT - pinout information requested please
Discussion in 'Hardware' started by moddingnewbie, 22 Mar 2013.
  1. moddingnewbie
    moddingnewbie What's a Dremel?
    21 Mar 2013
    Hi,
    Find CustomPC magazine fascinating to read particularly some of the rigs that readers build (phenomenal workmanship in all fairness) and wish that I had the motivation and organisational skills to get into some modding projects (not for want of trying). Am a newbie to modding in general (and hope that this question has been posted in the correct forum sub-category) and would like to ask whether anyone knows technical specifications and pinout details for the following please? This was attached to a DDR2 Module (possibly via a heat-spreader - cannot recall for certain) however whether this was fitted at the factory I'm not sure (at a guess it wasn't).
    Apologies for the quality of the photo.
    No idea whether this is programmable or whether the LEDs illuminate randomly.
    Thank you for any help.
  2. ferret141
    ferret141 Minimodder
    18 Oct 2010
    I would get a 3V source (two AA's maybe) and test the contacts to see if it light them up
  3. moddingnewbie
    21 Mar 2013
    Hi, Thank you for your reply. I'll give this a try and post back on here ASAP.
    Best Regards.
