Other Multiboot OS's
Discussion in 'Software' started by GTIgeneral, 19 Sep 2014.
  1. GTIgeneral
    GTIgeneral Minimodder
    31 Jul 2014
    So im starting to build a HTPC for the main purpose of using XBMC
    I'll mainly be using some sort of linux XBMC like openelec so that the computer will boot straight into xbmc when switched on.
    Is there a way to also install a windows OS and maybe have a OS selection screen by pressing a button during/after post?
    I know that i can install multiple OS's but don't want to have to select a OS upon every boot, only when i prompt for a selection screen.
    Hope you know what i mean, not very good at explaining :D
  2. bulldogjeff
    2 Mar 2010
    I think I know what you're getting at and the answer as far as I know is no. You can only run one at a time .The only way to jump between OS's the way you explained would be to run one as a virtual machine then you could just jump straight in to it.
  3. Pliqu3011
    Pliqu3011 all flowers in time bend towards the sun
    8 Aug 2009
    I have no experience with openelec specifically, but AFAIK this is certainly possible.
    GRUB for example will give you X seconds (you can configure this yourself) to pick one of the installed OSs before just launching the primary option (which you can also configure). Don't know if the Windows boot manager allows you to set a non-Windows OS as primary, but GRUB definitely does.
    Remember though: Windows will always have to be installed first, before any other OSs. (at least in my experience this avoids a lot of headache)
  4. GTIgeneral
    31 Jul 2014
    i think you misunderstood me, i dont want to run both at the same time. i want to have xbmc as the primary OS and have the option to select another OS at boot. but i want XBMC to boot automatically unless bypassed so to speak.
    Now this is along the lines of what im looking for. never heard of grub before, I'll take a look into it once im more sober :D thanks
  5. bulldogjeff
    2 Mar 2010
    are you on about dual OS's dual boot etc, if you istall both up there is and option in windows to set which OS loads. Widows boot loader will always take over. If not it can easily be sorted with a boot loader like easy BDC.it give you the option to configure what ever you want booting first. Or have I just totally got it wrong with what you're trying to achieve..
  6. GeorgeStorm
    16 Dec 2008
    It should be fairly easy to do, just make sure it defaults to the one you want, then it will always boot into that OS unless you choose the other during the boot process.
  7. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    ^This^
    Easy BCD can be a little tricky to get setup but it's very user configurable.
  8. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Almost all Linux distributions install "GRUB" (Grand Unified Boot Loader) as standard.
    This does EXACTLY what you're asking for. A default OS with the option to switch to another OS at boot time.
  9. Corky42
    30 Oct 2012
    Easy BCD uses NeoGrub that is based on Grub4Dos, so maybe the best of both worlds.
  10. mike_dowler
    mike_dowler What's a Dremel?
    17 Mar 2006
    +1 for easybcd
  11. theshadow2001
    3 May 2012
    Partition your disk first. Then install windows on one partition. Then install the Linux based os on the other partition. This will give you the grub boot screen every time your system boots. You can choose an operating system from there. You can edit the time out period and the default selection by editing a file in Linux.
    Things to note. Alway install windows first. Always select the custom install option on both operating systems so you can choose which partition to use. Create a gparted live cd and boot into that to set up your partitions before installing anything.
    I have installed Windows and Linux on two different disk. If I want to select the non default I hit f12 on the keyboard and just select the disk with operating system I want on it. Actually I have three operating systems done that way.
