News See the Antec P280 first at i44
Discussion in 'Article Discussion' started by Claave, 16 Nov 2011.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. Jipa
    5 Feb 2004
    To me it's NOT a shame not to see one of those damn 200 mm fans on the roof. If it's silence you're after, proper 120/140 mm fans are easy to find. BTW those new Antec fans actually are quiet...
    And for more photos, there's a gallery over at: http://www.anandtech.com/Gallery/Album/1111
    Looks good to me, might end up actually using this, or the new Solo II.
  3. Idioteque
    Idioteque Telephasic Mongoose
    21 Aug 2004
    I'm glad there's a new Antec case which focuses on classic smooth lines rather than those garish gaming cases they've been focusing on for the past two years. Looks nice.
    That aside, as Jipa said. Is a 200mm+ fan in the top really so difficult?
  4. racingrob
    racingrob What's a Dremel?
    4 Mar 2007
    I have just got rid of my P180 Mini after replacing the 200mm fan and that one chattered as well. being able to use any 120mm/140mm is a better option imho.
  5. Idioteque
    21 Aug 2004
    Well, there's that. I still love my delightfully silent Mini P180. Never had a problem with the top fan on low. Would be good to have the option of either 2*140mm or one 200mm+ fan.
  6. bogie170
    bogie170 What's a Dremel?
    11 Aug 2008
  7. Bede
    Bede Minimodder
    30 Sep 2007
    This is surely an advertisement for Antec and i44 and should be labelled as such..
  8. RedFlames
    23 Apr 2009
    +1 for 'thank glod they've ditched the "big boy"', it was the first thing to go [break] on my 1200
  9. Evildead666
    Evildead666 What's a Dremel?
    27 May 2004
    I hated the 200mm fan in my antec tower, it barely moved any air, and I just deemed it pointless.
    Much happier with a dual 120/140mm setup.
  10. wyx087
    15 Aug 2007
    would love to be able to block those top vents like in Fractal Design cases. current configuration seems like a neg-pressure case with dust sucked through the back vents.
    like the 2x120 fan placements. wonder if it's possible to put 2 240 radiators in this case? one on top, one on the HDD cage? that would make this an awesome watercooling case. there's more than enough room.
  11. delriogw
    delriogw What's a Dremel?
    1 Aug 2007
    d'oh, was planning on speccing for a couple of days, but can't afford to get there.
    typical.
    always been a fan on the range, but once i started attenting i-series i have to say i was less enamoured. they are not a great case to try and get to a LAN when you have no car and a very bad back :( hopefully this one will weigh a bit less than the usual baby elephant
  12. Jipa
    5 Feb 2004
    Yeah they sure aren't, but then again, that's kinda the whole point...
  13. RevDarny
    RevDarny Minimodder
    27 Oct 2011
    Do like the clean lines. This maybe the case to replace my P180
  14. azrael-
    azrael- I'm special...
    18 May 2008
    The dimensions of the P180 v3 are 514 mm (H) x 205 mm (W) x 507 mm (D), so one can hardly claim the P280 is smaller. The P280 seems to weigh in at a few kilos less than then P180 v3, though. Probably because it's a mere shade of its predecessors when it comes right down to it.
  15. PingCrosby
    PingCrosby What's a Dremel?
    16 Jan 2010
    I'll have a P please Bob.
  16. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    The fans in my antec 900 purchased in 2007 are all original and still as quiet as ever. I will be upgrading to this case over xmas, 900 gets too dusty.
  17. Vo0Ds
    Vo0Ds Fake potato
    6 Feb 2004
    Fractal R3 F.T.W.
  18. trig
    trig god's little mistake
    10 Aug 2006
    this looks to be a killer...and with the issues of the fractal door, may swing my money in antec's direction...read a few reviews and it is looking nice, and for $140
  19. Kiliv
    Kiliv What's a Dremel?
    2 Sep 2011
    i saw the case as it was being unpacked yesterday its very very shiny literally and fingerprints are a pain to get off even iff there is a cloth supplied for it, its built solid although looks like it would lack cooling which the sales rep from antec agreed with
  20. trig
    10 Aug 2006
    can see that. looks like no fans on the front for intake come with it...but i would imagine a couple of good fans for the front would make it just as good as the fractal at cooling if not better. but honestly, you're not buying this case for world class cooling...
Tags: Add Tags
