Build Advice Web Browsing PC - Unsure on PSU size
Discussion in 'Hardware' started by Deewon, 11 Sep 2012.
  1. Deewon
    Deewon What's a Dremel?
    29 Dec 2010
    Hi all,
    Looking at building the following for a grandparent for browsing and general tasks.
    AMD A4 3400, S FM1, Lynx Core, Dual Core, 2.7GHz - £41.21
    Gigabyte GA-A75-D3H - £59.70
    8GB (2x4GB) Corsair Vengeance Blue, DDR3 PC3-14900(1866) - £44.16
    128GB Crucial RealSSD M4 - £79.34
    Sony AD-5280S-0B DVD+RW - £13
    ATX Case - £30/35 (possibly free)
    430W Corsair Builder Series CMPSU-430CXV2UK - £35.32
    Total - £307.73
    Will the 430W be enough or should I go bigger? Would it be worth dropping to a lower brand for the PSU such as EZ Cool to save £15?
    Budget is about £300.
  2. Cei
    Cei pew pew pew
    22 Mar 2008
    8GB for browsing the internet? Seriously? Drop it to 4GB, and get cheaper non-Vengeance RAM as well, there's no need.
    Apart from that, looks fine. I'd keep the PSU as a Corsair, as you don't want to be dealing with it failing at a later date.
  3. Deewon
    29 Dec 2010
    Ok will drop the RAM to the 4GB (2x2GB) Corsair DDR3 XMS3 Classic, PC3-16000 - £26.88
    Thanks.
  4. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Used a couple of these recently (well the 550w version) for budget builds and they seem to be good.
    Antec Basiq 450w review
    They go for about £5 less than the corsair 430w one you have listed.
    Only £30 on scan at present but they are a pre-order.
  5. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Yes, it's more than plenty (even though the CX430 is a rebranded 380W unit). The system will likely pull around 100W on full load.
    No. Cheap units may fail catastrophically, and then they end up expensive.
  6. jizwizard
    jizwizard Modder
    24 Dec 2010
    The 430 will be plenty. Used a lot of these on budget systems and never had a single problem with them even when overloading them. Nice strong single rail
  7. tsutton
    tsutton Minimodder
    29 Aug 2003
    Don't forget the Windows 7 licence unless you're going with Linux?
  8. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
    You can use this site to calculate approximate power requirements.
    I inputted your stuff and came to approx. 203Watts. I wouldnt go any lower than the one you have picked just to be sure. :)
  9. mm vr
    18 Nov 2007
    That calculator overestimates rather grossly (to boost Thermaltake PSU sales? who knows). You can shave off a third of the result to get a more accurate value.
  10. Deders
    Deders Modder
    14 Nov 2010
    Not so sure about that, It estimates my rig pretty accurately, says I need a 497W PSU. I have a 500W which gives me about 100W headroom if my PC is ever fully stressed.
    For gaming it hits the most efficient halfway point so it should last longer.
  11. oliverr97
    oliverr97 What's a Dremel?
    31 Jul 2011
    Yeah a 430W psu should be fine for this build.
  12. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    I take it you've measured the power draw at the mains to know that it's pretty accurate?
  13. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Why go so over spec for something they are not likely to do much of anything with? Have you seen the foxconn nettops? I just got one for my parents to replace a dying athlon 64 I built in 2003. Got them an entire pc for about $170 as it only needed a stick of ram and came with an ocz vertex3 60GB in bundle deal. It's got an e-350 cpu in, which is plenty for thier light use and it fits neatly on the back of the display with a vesa mount. It scored quite a lot higher than the old athlon build across the board and it just sips power.
  14. Deders
    Deders Modder
    14 Nov 2010
    Yep, and factored in the efficiency of the PSU
  15. Metaporic
    Metaporic Minimodder
    30 Apr 2009
    The build looks decent, but it does seem somewhat over speced for a system that's sole use is inter browsing and (I assume) basic general tasks such as word and using media players.
    Id go with a Intel Pentium or Celeron, the built in 2k graphics should be more than enough, and if you go for something like the G530 you could still have enough for something like the AMD 6450 which will do fine and will have a faster system and perhaps even cash to spare when compared to the A4. You could then also save cash by opting for a more basic motherboard that still has SATA 6GB/s and USB 3, such as http://www.scan.co.uk/products/msi-...x-pcix16-1x-pcix1-1xpci-usb30-sata6g-vga-hdmi
    The SSD seems a tad over-kill, but then I suppose if its their only drive its a good idea, nice and fast, yet large enough for general use. Just so long as they don't collect a large amount of video and music.
    Regarding the original question, yes the 430 Watt PSU will be fine, particularly as its not likely to ever be fully loaded anyway. Id stick to trust-able brands (Corsair included ofc) as PSU's really do go poof and really do take out half your system when they do. Its just not worth the savings really.
  16. mrbungle
    20 Sep 2004
    Id keep the 8 gig of ram for the sake of saving ten quid tbh
