As per the title really. Looking for one for around £100 - £120 which leaves three options I can see, as it needs to be available from Overclockers.co.uk as I'm going over on Monday to pick up my new components. I read in one of the Bit-tech articles (can't remember which) that the Fenrir doesn't fit on the Asus P8P67, which I'm assuming includes the LE model, so that leaves the Gigabyte P67A-UD3 or the MSI P67A-C45. Between the two, I'm leaning more towards Gigabyte's offering, so if anyone knows if it will cause a problem with my cooler, I'd be really grateful.
It does and should fit because the holes are the same for socket 1155 & 1156 but I remember the heatsinks blocked the fan from being mounted, not the actual layout. I have a Gelid Tranquillo which is socket 1156 and it fits fine on my P67 PRO
