Other FreeSAT
Discussion in 'General' started by goldstar0011, 24 Sep 2013.
  1. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    Howdy
    Just cancelled SKY and wondering can I use the SKY dish with a freeSAT box all ok?
    I have a freeview aerial but signal isn't that great and might need a new one
    Thanks
  2. badders
    badders Neuken in de Keuken
    4 Dec 2007
    Yep, that's what I'm doing right now. Works perfectly for me.
  3. CrazyJoe
    CrazyJoe Modder
    4 Aug 2010
    Your sky box will turn into a very good freesat box when your subscription runs out.
  4. lp rob1
    lp rob1 Modder
    14 Jun 2010
    FreeSat is pretty decent, but make sure you get a good set top box. The low-end Grundig one really is low-end...
  5. Sp!
    Sp! Minimodder
    6 Dec 2002
    if you don't need PVR functions your skybox is as good as any cheap free sat box you just need to leave your viewing card in.
  6. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    To get the full service (Channel 4 and Channel 5), remember to contact Sky for a freesat viewing card - cant remember the cost but it's minimal.
  7. CrazyJoe
    CrazyJoe Modder
    4 Aug 2010
    The viewing card used for the subscription will do, no need to order another one.
  8. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    My bad, believe this used to not be the case.
  9. theshadow2001
    3 May 2012
    I'm not sure about the sky box making a goo freesat box. The menu is full of sky channels you can't watch. Its just annoying. I'd just go for a dedicated freesat box
  10. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    ^What he said. My Dad has an old Sky box and ~90% of the channels are just a blue screen essentially; whether you can program the box to skip these channels like you can on a normal box is another question..
  11. goldstar0011
    2 Sep 2007
    Cheers, think I'll contact the old Freeview box for the PVR function whilst I look for a new Freesat box
