Scratch Build – In Progress Arya-completed
Discussion in 'Project Logs' started by Pranja, 18 Feb 2013.
  1. Pranja
    Pranja Blackwolf
    18 Dec 2011
    For the last three months I have been planning a small office/multimedia PC made of wood.
    I was waiting to finish my semester at college and now,when it is over-I presend you my project-Arya.
    Here are rendered images of Arya.
    Yesterday, my friend brought me box containing the laser-cut wooden parts.
    And today,after some playing with the parts:
  2. tekonivel
    tekonivel Minimodder
    14 Jul 2012
    You have found your style. Will be following.:thumb:
  3. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Thanks. :thumb: Although, I don't understand-what do you mean when you say "You have found your style."?
  4. tekonivel
    14 Jul 2012
    I mean this has similar construction style as scorpio. and they both look awesome.
  5. Pranja
    Pranja Blackwolf
    18 Dec 2011
    I see-thanks for explanation. They are similar construction because my friend's CNC machine only have two axes. If we had CNC with three axes, construction would be different a lot. :lol:
  6. Cheapskate
    13 May 2007
    OOOH! You should have added a little extra material so you could sand the whole thing round.
  7. Pranja
    Pranja Blackwolf
    18 Dec 2011
    You mean because the black stuff? I actualy like it that way. It shows the shape of case little bit better. :D
    Todays progress-side panels assembled.
  8. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Today I continued my work on Arya.
    Second side panel is finished.
    I received brown paracord and golden power button.
    One meter long steel rod+saw=
    :D
    Assembly of top and bottom of the case.
    Top and bottom mounted on the case.
    Mockup with side panel.
  9. Pranja
    Pranja Blackwolf
    18 Dec 2011
    New and better pics of Arya.
  10. faxiij
    faxiij Minimodder
    25 Jan 2011
  11. Pranja
    Pranja Blackwolf
    18 Dec 2011
    That is nice design.
    But this mod is not related to it in any way.
    Thanks for the link. :)
  12. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Today work on the project continued.
    Golden power switch with brown paracord on cable.
    Front panel had too long cables and too many connectors.
    USB connectors are placed on mini PCB's with extended cables.
  13. Pranja
    Pranja Blackwolf
    18 Dec 2011
    New parts arrived an hour ago. :D
    Front part covered with leather, rear part and new spacers.
    I will post better pics tomorrow.
  14. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Today I placed fornt USB connectors and I/O shield. You can see the size od Arya compared to that I/O shield. :D
  15. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    Looking good. I like the look of the front piece with the leather, combined with the wood.
  16. Waynio
    Waynio Relaxing
    20 Aug 2009
    This is really nice, :) got to love layers, enables complex shapes & retains strength. :D
  17. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Thanks jokkos. I am actually thinking of using more leather on Arya-maybe I cover this bottom ring with leather. :)
    Thanks Waynio. :thumb: Layers are nice,but they are PITA to put together. :lol:
  18. Asouter
    Asouter --------
    18 Jan 2012
    Ohh the joys of using layers, they are a pain aren't they :) The spacers make it a lil easier, how many times did you forget to use one and have to take it apart again ? :D
  19. Pranja
    Pranja Blackwolf
    18 Dec 2011
    :D I didn't forgot any spacers,but few times rod fell out from hole and I had to put everything back. :wallbash:
  20. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Today I worked on the electronics again-this time it was the RGB LED's with remote control (now you know what the smallest hole in front serves for :D).
    Of course I didn't like the look and size of the controller, so I mod it a "little". XD
    PCB is insulated.
    And now the fun part.
    And small video of me playing with controller.
