News Lenovo caught bloating PCs as profits plunge
Discussion in 'Article Discussion' started by Gareth Halfacree, 13 Aug 2015.
  1. Gareth Halfacree
    4 Dec 2007
  2. greigaitken
    greigaitken Minimodder
    26 Aug 2009
    Surely behaviour like this is grounds for every customer to take court action and would be entitled to way more money than the laptop cost.
  3. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    The other companies involved in the UEFI Forum should have blocked the introduction of the Windows Platform Binary Table (WPBT), it's nothing more than a DIY rootkit installer.
  4. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    As usual, companies' consumer laptop/desktop lines are full of ****, and the business lines are fine.
  5. Corky42
    30 Oct 2012
    I wouldn't be so sure that business lines are fine, WPBT was introduced in Windows 8 so all modern (circa 2011 onwards) computers come with the ability to inject "wpbbin.exe" and have Windows automatically run it during boot.
    HP have been doing a similar thing for years with their Computrace tools, the only reason Lenovo have been caught out is because they used WPBT in a way that was against Microsoft's recommendations.
  6. Locknload
    Locknload Jolly Good Egg
    28 Jun 2009
    Toshiba have been doing this for years on laptops.
  7. Gareth Halfacree
    4 Dec 2007
    What, injecting insecure bloatware into an anti-theft feature that causes it to survive fresh OS installs from the customer's own media? If you've got a source for that, that's one of Monday's news topics sorted...
  8. rainbowbridge
    rainbowbridge Minimodder
    26 Apr 2009
    if you remove all partitions, including say a full zero wipe against the drive (killdisk) does the software still reinstall? if it does then this is from the actual security chips with in the computer and should be able to be turned off in the bios?
  9. RedFlames
    23 Apr 2009
    Whilst it's only anecdotal, If memory serves Tosh's TEMPRO monitoring gubbins and other OEM bloat is an utter twunt to remove and again iirc it survived a 'burn it and start over' reinstall of windows... however this was a while ago and I'm not wiping the 'rents laptop to test a theory...
  10. ArcAngeL
    ArcAngeL What's a Dremel?
    14 Nov 2006
    This is why i love the surface pro line, zero add in bs. Its also why australias education department dropped them as a supplier.
    With the layoffs they bette rstart with their software devision. And the staff responsible. Otherwise i would say this is an act of goverment spying.
  11. Corky42
    30 Oct 2012
    Even changing your drives wouldn't get rid of it as it's contained in the UEFI BIOS, supposedly there's a switch in the BIOS to disable WPBT, the section that loads "wpbbin.exe" into memory that in turn Windows writes to disk, but I've read that some people have found "wpbbin.exe" on their system and don't have the ability to disable WPBT in the BIOS.
