Modding 101 part1: castors, handles and side windows.
Discussion in 'Article Discussion' started by moose, 12 Aug 2003.
  1. moose
    moose What's a Dremel?
    12 Mar 2001
    http://bit-tech.net/article/112/
    As the news post:
    Our very own Macroman kicks the ball rolling, revealing some modding secrets, in this the first of a bit-tech brand series of 'Modding 101' guides. New and experienced modders alike should find something of interest in these detailed and easy to follow articles. Where better to start than the begining, so back to basics and read on to get the Macroman low down on fitting castors, handles and a side window.
    Got any comments, questions, death threats? Let us know here :)
  2. DeX
    DeX Mube Codder
    22 Jul 2002
    This should be renamed to the modding 404 guide :(
  3. moose
    12 Mar 2001
    Try again.. my wee fingers aren't as quick as they used to be :)
  4. M_D_K
    M_D_K Modder
    3 Apr 2002
    not bad dude can't wait for the update on that one :D
  5. wharrad
    wharrad Minimodder
    26 Jul 2003
    Ahhh! Careful, EXPENSIVE case their friend!!
    I likes the move of the window there, adds to the minimalistic nature of the case... sweet :D
    I hope you plan to add 2 80mm fans on the motherboard tray - I'm lucky enough to have that tray and was thinking about adding another fan to that rear and a Black Ice Micro 2 rad. I figure there's about 2mm spare - so it'll look professional and that. :dremel:
  6. Green Soda
    Green Soda What's a Dremel?
    26 Dec 2002
    nice little guide, but when are you going to work on macroblack....
    :D
  7. trifin
    trifin What's a Dremel?
    14 Jul 2002
    hi,
    thx for the article - useful as ever.
    can u let us know of the suppliers for handles and castors ?
  8. wharrad
    wharrad Minimodder
    26 Jul 2003
  9. trifin
    14 Jul 2002
    thx... and the castors ????
    ive looked for castors for ages now but with not luck - none of the usually suppliers stock them anymore :(
  10. macroman
    macroman The One
    3 Sep 2001
    B&Q ;)
  11. trifin
    14 Jul 2002
    of course !!!
  12. bee2643
    bee2643 What's a Dremel?
    7 Mar 2002
    i like the idea of these articles...wouldnt mind seeing:
    the top window mod
    making blowholes
    case painting
    and wire cleanup
    ...would be a nice bit to throw in, i know alot of ppl who have made killer cases but the wiring is still poopey, i myself -had- one of those cases...i think ive now mastered the art of cable tidying ;)
    let me know if you want a partner for that :hip: :naughty:
  13. Slartibartfast
    Slartibartfast What's a Dremel?
    22 May 2002
    I need to replace the plexiglass on my Lian Li case, which is held in place with aluminium plates riveted to the panel.
    I like the look of the hex-headed screws that are used in the Coolermaster case featured in this article, and I'd like to replace the rivets with these when I replace the plexi.
    Anyone know where I can get them from (or some like them)? I've tried the big DIY stores like B&Q and Homebase without luck, even tried Screwfix direct - no cheer.
    Ideas anyone?:dremel:
  14. bee2643
    7 Mar 2002
    well igot some that i used for my fan grills a while back
    got very similar ones from home depot
    ....guess theres no home depot in the uk :p
  15. Daishi
    Daishi What's a Dremel?
    18 Jul 2003
    Just bought a CM101 took 1 look, jumped out to Macros modding 101 and started in on it.
    Please please write the rest of this article :)
    Thanks for all your hard work macro, n00bs like me really appreciate it.
    - Daishi
Tags: Add Tags
