Graphics Budget graphic for gaming
Discussion in 'Hardware' started by Jot1321, 10 Feb 2012.
  1. Jot1321
    Jot1321 What's a Dremel?
    10 Feb 2012
    Hi,
    I have just completed building a new PC and sadly for the time being only got a budget of £40 :wallbash: for a graphics card. i need it for some gaming although not lots because it is only cheap.
    please can someone make some suggestions i have been searching for days and cant pick the correct one.
    thanks. :thumb:
  2. ninjaplease
    ninjaplease I don't know what I'm doing
    11 Jan 2012
    I'm using an Asus ATi HD 5670 1GB DDR3, got it off amazon for £61 which is out of your price range however I regularly play Rage, MW3, Crysis 2, Portal 2 etc etc on pretty high detail levels and I'm yet to have a problem.
    It's not worth skimping on a GPU, you'll only regret it when you have to fork out for a decent one in a few months.
  3. mucgoo
    mucgoo Minimodder
    9 Dec 2010
    No hope of getting anything new.
    Your best bet is hoping one of the lovely folks here offers you a 8800/9800 vintage chip for P&P.
    Otherwise look on ebay for a GTX260 or HD 4850.
  4. dunx
    dunx ITX is where it's at !
    1 Sep 2010
    I run a 700 MHz GTX 460 1 Gb @ 900 Mhz, these are around £50 on ebay...
  5. Mac_Trekkie
    Mac_Trekkie Source Engine's #1 fan!
    10 Sep 2011
    If you want something new your best bet would be a GT 240/440 1gb GDDR5, as those actually have decent performance at medium settings. Better would be to look for an 8800 or 9800 or GTX 260(all essentially the same card) on ebay, or the marketplace(you need 75 posts to get in there).
  6. mucgoo
    mucgoo Minimodder
    9 Dec 2010
    Then your were very,very lucky.
    460's are worth more like £80~
  7. dunx
    1 Sep 2010
    Wanna buy three ?
    LoL
    dunx
  8. Mac_Trekkie
    10 Sep 2011
    It might be the SE version, which is still worth more than 50, but significantly less than a true GTX 460.
