Case Mod - In Progress [Worklog] Project "Red Phoenix" by FlowMods
Discussion in 'Project Logs' started by FlowMods, 10 Feb 2016.
  1. FlowMods
    FlowMods Modder
    20 Jan 2016
    Hi all guys!
    This is my second project of this 2016 and it am currently rendering it and looking for ideas, everything by you is well accepted!
    It is a BitFenix ​​Prodigy ITX Red, it is the first time I am working on a case of this size, it will be a challenge!
    As always in my project, it will feature Plexiglass laser cut parts on my design, and a liquid cooling system, probably with rigid pipes, or secondary option yet to be determined, with black flexible tubes 13/10
    As the name says, the colors will obviously be red / black classic, hoping to mix them well
    Unfortunately, this project should have started many months ago, for several personal problems I delayed it a lot, and I must apologize to BitFenix, who long ago gave me the material.
    Anyway now I'm here dealing with sizes and designs and are looking for sponsors to start this new project
    I leave you some render, of course WIP! The suggestions from you are in order to improve the project prior to the pieces for the construction, any idea that comes to your mind is welcome!
    Thanks to:
    And photos about components i will be using!
    Thank you in advance and... soon new updates!
  2. Shirty
    18 Apr 1982
    Moved to planning until we see some actual modding, as per the rules :)
  3. FlowMods
    FlowMods Modder
    20 Jan 2016
    New renders and.. work started!
  4. FlowMods
    FlowMods Modder
    20 Jan 2016
    Thanks to Alphacool , Aquatuning and Phobya!!!
  5. FlowMods
    FlowMods Modder
    20 Jan 2016
    Start!!!!
    The frontplate project:
    Stay tuned!
  6. Shirty
    18 Apr 1982
    Moved back to logs - good luck!
  7. FlowMods
    FlowMods Modder
    20 Jan 2016
    New package from Aquatuning! Awesome!
  8. FlowMods
    FlowMods Modder
    20 Jan 2016
    Thank you!! :D
  9. FlowMods
    FlowMods Modder
    20 Jan 2016
    New frontplate try!!
  10. FlowMods
    FlowMods Modder
    20 Jan 2016
    Update!
    - Radiator mounted with new top radiator support made by cnc laser
    - New pump support made by cnc laser in acrylic
    - Loop started with first tubes and the valve
    I am watigin for the mobo so than i can go ahead!
    Photos!
  11. FlowMods
    FlowMods Modder
    20 Jan 2016
    Little update!
    Sleeved power switch cable and cutted the case to fit the valve :D
    I also conneted the front and upper fan cables to have only 1 cable to the controller :D
    Photos:
    Stay tuned!
  12. FlowMods
    FlowMods Modder
    20 Jan 2016
    Small up waiting for the mobo and cpu!!
    I shortened the 24pin cable to fit with this beatiful itx case and made the cable for the controller and hdd! :D
    And.. a fantastic badge on the front! :D
  13. FlowMods
    FlowMods Modder
    20 Jan 2016
    Project continues! Arrived H81M-ITX + G3258 and everything assembled! Loop finished and led installed!
    Wiring finished and loop under test with temporary transparent liquid! I hope next week having finished everything with custom side panels ;)
    Stay tuned!
  14. FlowMods
    FlowMods Modder
    20 Jan 2016
    The mod is finally finished!
    Really thanks to BitFenix and Alphacool that made all this possible!
