Case Mod - In Progress THE STAGE COACH WELLS FARGO by MPC
Discussion in 'Project Logs' started by MPC, 1 Nov 2015.
  1. MPC
    MPC Minimodder
    24 Oct 2015
    - HARDWARE
    CPU: INTEL HASWELL-E I7-5960X
    MAINBOARD: MSI X99S GAMING 7
    GRAPHIC CARD: MSI TWIN FROZR GAMING GTX770
    POWER SUPPLY: COOLER MASTER V1200 PLATINUM
    RAM: KINGSTON PREDATOR 16GB ( 4X4GB ) DDR4 2666 MHz CL14
    SSD: KINGSTON HYPERX FURY 120GB x2 PIECES
    COOLER: COOLER MASTER NEPTON 240M
    - SPONSORSHIP by : MSI , COOLER MASTER , KINGSTON
  2. MPC
    MPC Minimodder
    24 Oct 2015
    Introduction:
    This is an accurate reproduction of a '800 stagecoach in every detail.
    Some changes were necessary, it's obvious, to insert the components as best I can.
    Here is a reference of the stagecoach history: https://en.wikipedia.org/wiki/stagecoach.
    I started working aluminium road signs, size 60×60×0,3 cm, kindly given by a friend of mine.
    Then I rounded the two sides using my great jigsaw Proxxon DSH.
  3. MPC
    MPC Minimodder
    24 Oct 2015
    I brazewelding the two sides' convexity with Durafix welding torch and rod then I used epoxy resin to have a strong blocking.
  4. MPC
    MPC Minimodder
    24 Oct 2015
    With the Optimum milling machine I realized little doors and convexity using the same technique of parts anchoring.
  5. MPC
    MPC Minimodder
    24 Oct 2015
    Given that the sides are 3 mm depht I prefered to realize the outlines so as to increase the material layer on the fixing spots with lateral sides that are a 5 mm depht single-piece.
    Let's do a foursides' assembly test..
    The lineup seems perfect!
  6. MPC
    MPC Minimodder
    24 Oct 2015
    The upper part is good so now let's realize the frame using 5 mm depht aluminium sheet to create supporting metal struts.
  7. MPC
    MPC Minimodder
    24 Oct 2015
    At the end the execution of many details that will be part of the frame with 2 and 1 mm depht brass sheets.
  8. Icelander
    Icelander Minimodder
    3 Mar 2015
    This is Crazy. Great looking, and those tools/workshop :jawdrop:
  9. MPC
    MPC Minimodder
    24 Oct 2015
    Thanks man ! ;)
  10. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    Nice milling machine Marco :jawdrop:
    Looking at the pieces it seems you have some schemas to build up the stagecoach.
    Am I wrong ?
  11. MPC
    MPC Minimodder
    24 Oct 2015
    Hello Kappa, thank you!
    I initially had seen a horse-drawn in a flea market but this was too small. In the end I decided to base myself on the Wells Fargo model where I proceeded to do the sketches so as to have an internal space large enough for e-ATX motherboards.
    I have complied with all the proportions and the historical characteristics of this stagecoach.
    With all these pieces it is essential to number each piece and to have a plan in mind ;)
  12. Cheapskate
    13 May 2007
    Love what you are doing, but traffic signs? :eyebrow:
  13. MPC
    MPC Minimodder
    24 Oct 2015
    Thank you ! :)
    Yes, old traffic signs were replaced. I have a friend of mine who works in this area and gave them to me.
    These signs are made of aluminum so with a sander I have brought back them to the natural state of the raw material without spending more money for aluminum. :D
  14. MPC
    MPC Minimodder
    24 Oct 2015
    Overall test.
  15. Mockingbird
    Mockingbird What's a Dremel?
    7 Sep 2011
    This is a really unique mod and obviously one quite personal to you - are you interested in stage coaches specifically, or is it that period of history?
  16. Waynio
    Waynio Relaxing
    20 Aug 2009
    Nice work, subbed. :)
  17. MPC
    MPC Minimodder
    24 Oct 2015
    Thank you !
    I think that a modder used a lot by observing their work.
    I have a passion for this stagecoach after seeing a flea market a horse-drawn simple.
    From now on movies west I look at them with greater passion :D
  18. MPC
    MPC Minimodder
    24 Oct 2015
    Thank you Waynio :thumb:
  19. Vault-Tec
    30 Aug 2015
    Nice. Different, too. Just lately I had the idea of making a mini Airstream trailer for an ITX build.
    Sadly I have no time, no tools, no talent working with metal and no money. So that kind of ruined it :D
  20. MPC
    MPC Minimodder
    24 Oct 2015
    Thank you !
    It 's true, it is a mod totally different from what you see.
    Build cases for PC is my passion and I'm slowly equipping of many machines. Lately I bought a cnc pantograph that I will use for the next project.
    In this mod I have made many pieces by hand where fortunately the manual is my highlight.
    Only passion can give you patience in building pieces also relatively long and difficult. ;)
