I'm going to be doing a major revamp of my build this week. I have a Koolance RP-452x2 dual reservoir and have been looking at the option of running two pumps in serial using the 180 degree adaptor that Koolance provide separately (shown in the second picture) This, in effect uses two pumps to drive a single loop, which I figured might be handy seeing as I will be cooling 3 x 580's in parallel (which I know requires more pressure than serial), aswell as the CPU, whilst negotiating a pair of RX360 radiators. Opinions would be much appreciated. Cheers.
If you don't have motherboard blocks and you run the cards in parallel then a single pump would be OK. If you also have motherboard blocks it'll be borderline. If you run the cards in serial then I think you'd need another pump. 2 Pumps would give you redundancy though.
Cheers. I don't have motherboard blocks and have no intention of running the GPU's in serial, but based on what you have said, it seems I would be on the edge of what a single pump can handle. I'm probably leaning towards dual pumps.
A useful tool for getting a rough idea is Martins Rad Optimiser spreadsheet If it doesn't have the components you use then pick similar ones.
And Bitspower fitting are cheap? Koolance don't seem that expensive, maybe a £10 premium on some items.
