Cases Lian Li PC-Q11 for gaming? EDIT:What about Q25?
Discussion in 'Hardware' started by hm1992, 18 Nov 2011.
  1. hm1992
    hm1992 What's a Dremel?
    28 May 2009
    It has room for a 240mm gfx card
    However no one has reviewed it (I have found 2 reviews online) with a decent processor/GFX
    Heat and noise tests mean nothing with an intel atom board inside as temps are so low
    Could anyone tell me whether it could work as a mini gaming pc?
  2. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    You'd do better with the PC Q08. It has much better airflow, is slightly roomier and is usually not much more expensive if at all.
  3. GeorgeStorm
    16 Dec 2008
    I'm using a Lian Li PC-Q08 as my current media pc, but I've had it as a gaming pc aswell (i5 670 and 5870) no problamo, is awesome having so much power in such a small case, makes me almost regret getting my 800D :p
  4. hm1992
    28 May 2009
    Wow guys thanks for quick responses.
    Having looked at some more reviews etc it looks like the q11 doeasnt have a great amount of cooling power compared to the q08.
    However I could use a pc-q11.
    I guess i dont need an internal dvd drive as i dont need one all the time (I plan to carry the pc around occasionally for communal editing projects with no need for a dvd drive there).
    Is the airflow better or worse in the Q11
