Graphics Graphics Upgrade Advice
Discussion in 'Hardware' started by Promethus, 15 Nov 2015.
  1. Promethus
    Promethus What's a Dremel?
    2 Nov 2008
    I am currently looking to upgrade my graphics cards. The current system configuration is:
    Intel i7 980X
    Asus Rampage Extreme III
    24GB Samsung RAM
    Corsair HX1000 PSU
    2x EVGA 670 Cheesecake
    I am going to be moving the two 670s to a secondary PC, and so I am looking for an upgrade to my primary desktop. I was thinking a pair of EVGA 970 FTWs. It is used for gaming, fps/simulation/strategy, and some video encoding. I will not even consider AMD cards (had one before, never again).
    Should I consider holding off until the next generation of Nvidia cards come out?
    Is the age of the motherboard going to hold back any GPU upgrade?
    Is there anything else I should consider, before purchasing?
    Thanks
  2. spolsh
    spolsh Multimodder
    4 Feb 2012
    I'd consider a 980ti instead of 2 x 970's. Similar performance from the reviews I've seen, and probably not much difference in price. Also avoids the whole 3.5GB VRAM thing and any scaling issues with SLI.
  3. Vault-Tec
    30 Aug 2015
    What resolution do you game at?
  4. johnim40
    johnim40 Minimodder
    23 Apr 2009
  5. trueno!
    trueno! That's TRUE-N-NO if ure not sure!..
    24 Apr 2009
    I would have to agree with spolsh as well seeing as you would get 6GB of effective ram to work with instead of 3.5GB + 500MB of slower clocked ram shared between the two 970s, in addition going with a 980Ti will give you the future option to go SLi another!..
    Sent from my GT-I9300 using Tapatalk
  6. Teelzebub
    27 Nov 2009
    As SLI user I would agree with the others here get yourself a single more powerful GPU and later get another as needed.
    I've had SLI for almost as long as I can remember and never had a problem but the best way is to start with the better card and build on that
  7. Promethus
    2 Nov 2008
    Apologies for the slowness of the reply.
    Current resolution is 2560x1440, but I am looking to get an Oculus Rift once they reach retail.
  8. thom804
    thom804 Minimodder
    22 Oct 2009
    After being dissuaded from getting 2 x 380Xs and investing in a single Fury X (on this very site, I might add!), I can comfortably say that the new top end single card solutions will mash pretty much anything @1440p.
    Whether your Green, Red, or doesn't matter, the Fury X and 980Ti are pretty much optimal (for me) at 1440p.
  9. jinq-sea
    15 Oct 2012
    If you're Team Green, get yourself a 980Ti. I'd take that as a better option over 2x970, largely for the reasons set out above! :thumb:
