Displays monitor stuck in boot loop
Discussion in 'Tech Support' started by I'm_Not_A_Monster, 2 May 2011.
  1. I'm_Not_A_Monster
    I'm_Not_A_Monster Hey, eat this...
    22 Dec 2003
    earlier today i went to turn on my monitor and it started boot-looping. the light on the power button lights orange for a split-second, then straight to green, then the backlight turns on for a moment, then screen off/button off.
    over and over and over.
    hitting the power button doesnt seem to do a whole hack of a lot. i am unable to make the screen stop this loop unless i unplug it from the wall. i've also tried holding down the button like how you can force a PC to shut off, but it doesnt work either.
    my monitor is a Dell E193FPc (note the lower-case c) monitor connected to my PC via a VGA cable.
    my PC was on at the time, and didn't start making any noises or system beeps when the monitor failed, so i dont think the issue stems from the video card failing or overheating. but i could always be wrong
    thanks for any help
  2. tehBoris
    tehBoris What's a Dremel?
    30 Jan 2011
    You need to test the display with another source.
  3. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Also try another cable, just to eliminate it from the equation.
  4. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    i would say the power supply has packed up, had this recently with a customers screen
  5. Chicken76
    Chicken76 Minimodder
    10 Nov 2009
    +1 for the monitor's power supply.
  6. bulldogjeff
    2 Mar 2010
    Boot looping? if it's what I think you're saying, then it's not the monitor, it's a corrupted boot loader.
    Use your windows disc and try to reinstall the boot loader.
  7. I'm_Not_A_Monster
    22 Dec 2003
    the monitor is boot looping, not my computer. the monitor itself goes standby-on-off forever.
    it was the closest term i could think of to describe the situation
  8. GregTheRotter
    GregTheRotter Minimodder
    9 Aug 2008
    What would you say is the cost to replace the power supply? Don't mean to hijack the thread here, but I've got a sony 19" lcd that's been repaired under warranty for the same problem I think, and I was contemplating whether to have it repaired or not, or just spend £100 or so and get a new one with full warranty.
  9. I'm_Not_A_Monster
    22 Dec 2003
    I don't mind the hijack at all, if its cheap I'm sure its something I could do too. I'd imagine its probably as simple as looking on eBay for the monitors model (which is also how I find laptop internal parts)
  10. GregTheRotter
    9 Aug 2008
    I'm not sure where I'd find the part number, I have no knowledge of soldering, so I'd be more inclined to get it done by a technician. I was more interested in knowing what the cost of the work would be.
  11. RichCreedy
    24 Apr 2009
    is the power supply in the monitor, or an external brick?
    if it's internal, might be cheaper to buy a new monitor
    brick will cost between £20-£35 ish
  12. tehBoris
    30 Jan 2011
    alternativally, if he knows a bit about electronics, could open the monitor and determine what voltage (probably 12v) it needs and may be the current it can provide (probably 5A+), get a power supply accordingly, wire up an external power connector.
    Effort++, money--;
  13. GregTheRotter
    9 Aug 2008
    Bah, it's internal. Good job it's not mine (family pc) and we've got a old crt monitor we can use.
  14. RichCreedy
    24 Apr 2009
    one suspects if he had to ask he doesn't have the required skillset to repair it
