Case Mod - In Progress Project: Stainless Steel [Finished]
Discussion in 'Project Logs' started by EMF, 13 May 2015.
  1. EMF
    EMF What's a Dremel?
    9 Apr 2015
    Project Name: Stainless Steel
    Designed & Built by -C3r34L3- of the Extreme Modding Factory
    Project description:
    The materials that I will use will be metacrilato (Plexiglass Alias) and stainless steel Scotch brite fin and I'm going to create:
    1. New "Back-stand" of the case where i will insert the mobo and reservoirs
    2. New midplate of the case headquarters of the pumps
    3. Various flanges and mod of the case
    As you will see in3d render inside the "back-stand" and "midplate" will be drilled internal circuits used insted of acrilic tube for connection between the various elements of the watercooling rig
    The construction technique of these blocks will be very similar to the standar WB that we use.
    all the stuff in the project are prototyped with 3d modeller and built with our CNC machine :thumb:
    Hardware:
    • Case: Corsair 900d
    • CPU: Intel Core i7-4960x Extreme Edition
    • Mobo: Rampage IV Black Edition
    • Ram: DDR3 2133Mhz 32GB Corsair Dominator Platinum
    • GPU’s: 2 x GTX980
    • PSU: Cooler Master V1200
    • SSD: 2 x Samsung SSD Serie 840 Evo 250GB SATA III in RAID 1 / 3 x Kingstone SSD HyperX 3k 240 GB RAID 0
    • Pump: 2 x Laing DDC- 3.25
    • Fun: 16 x Cooler Master JetFlow 120
    Control:
    • Fun: Aquacomputer aquaero 5 LT
    • Pump: Aquacomputer poweradjust 2 USB
    • Sensor: air and liquid by Bitspower
    • Flow sensor: Bitspower
    Liquid cooling:
    • Rad: 2 x Aquacomputer airplex modular 480mm Steel fin
    • Mobo Block: Full board Bitspower
    • GPU’s Blocks: Bitspower
    • RAM Bolcks:Bitspower
    • Res:Bitspower
    • Pump cover:Bitspower
    • Fittings: Bitspower
    • Tube: Bitspower
    Cable & cable manegement stuff:
    •all by ICEMODZ
    Lighthing & machining:
    • Powered by EMF
    My sincerest thanks to these wonderful companies for sponsoring our project
  2. EMF
    9 Apr 2015
    Work log DAY 1 - Dismembering & removing paint
    I all guys, here we go!.. and i hope u like it :thumb:
    As u can see in the render i have to change "something" about the 900D...here some picture of the moddin DAY
    See u soon and stay tunned :dremel:
  3. DanielSandsFTW
    DanielSandsFTW What's a Dremel?
    23 Mar 2015
    This is going to be incredible! Beautiful renders.
  4. Bygone
    Bygone Minimodder
    15 Apr 2015
    Looking good...renders are gorgeous, look forward to seeing it Progress.
  5. EMF
    9 Apr 2015
    :rock:
    :thumb:
  6. EMF
    9 Apr 2015
    Work log DAY 2 - Mechanical production
    From rendering to reality :D..
  7. Cheapskate
    13 May 2007
    Great start. I'm not sure why you didn't just make the whole thing from scratch, though.
  8. BeeP
    BeeP Minimodder
    17 Dec 2009
    Wow nice equipment, looking forward to this.
  9. EMF
    9 Apr 2015
    yes i could do it...but i really like to mod that case first.
    Tnks :rock:
  10. EMF
    9 Apr 2015
    Work log DAY 3 - Fitting & Painting
    ...i decided to paint it black matte fin "texturized"...first of all i have fitted all the parts :thumb:
    ..& now i'm ready to start building something...
    See u soon :dremel:
  11. EMF
    9 Apr 2015
    Work log DAY 4 - Start building somethings
    see u soon :thumb:
  12. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    New mobo-try and midplate are an amazing combo !!! :jawdrop:
    Subbed
  13. EMF
    9 Apr 2015
    Ciao Dot...
    sono contento che ti piaccia ;-) :rock:
  14. Arcis Modz
    Arcis Modz What's a Dremel?
    31 May 2015
    looking good.
  15. EMF
    9 Apr 2015
    Hi Guys...here some picture of the baby ;)
    see u soon :dremel:
  16. Bygone
    Bygone Minimodder
    15 Apr 2015
    looks very nice...i love that back plate for motherboard tray with Water routing in...
  17. Icelander
    Icelander Minimodder
    3 Mar 2015
    pure awesomeness
  18. Cheapskate
    13 May 2007
    Looks fantastic.:D
  19. EMF
    9 Apr 2015
    Work log DAY 5 - Start building lighting parts
    https://lh3.googleusercontent.com/9iDOjDjA1DC4phxYemeKOywLAzNeqneOAXTTP5yRsRk=w668-h1112-no[IMG]
    [IMG]https://lh3.googleusercontent.com/ateDRAP5AyM6StsmtdEJHmTruyhomswuPf2cf7a8-JY=w240-h400-no
    ..sorry for the quality but my reflex go down :duh:
  20. sangyzan
    sangyzan What's a Dremel?
    17 Aug 2014
    Amazing job bro..... :D
