Modding Mobo standoffs tapping help
Discussion in 'Modding' started by JamieElston, 22 Feb 2012.
  1. JamieElston
    JamieElston What's a Dremel?
    23 Oct 2011
    Hi all,
    as part of my project I need to install some motherboard standoffs in to a piece of perspex.
    I have never tapped before and have seen several kinda conflicting guides.
    Whats the correct drill bit size and tap size? Ive been told I would need a 6/32 tap?? unsure of the drill bit size...and any general tips would be great.
    Thanks in advance.
  2. Big Elf
    23 Apr 2009
    It is a 6/32 thread. You can get taps/dies/tools from here but you may be able to find them cheaper elsewhere. That's the total limit of my knowledge. I've just used the taps to 'refresh' screw holes.
  3. ninjaplease
    ninjaplease I don't know what I'm doing
    11 Jan 2012
    Word of advice-be VERY careful and slow when working with brittle plastics like perspex, they like to crack and/or shatter....
    Personally I'd advise drilling a clearance hole and finding a way to secure the threads into something metal, that's if you can get away with is aesthetically.
  4. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    some Standoffs are m3 so be careful when ordering taps you get correct one
  5. dynamis_dk
    dynamis_dk Grr... Grumpy!!
    23 Nov 2005
    Get a scrap bit and try a few times to get the best combo of pilot hole ad tap technique. Different metals or plastics can tap differently so the small practice run is well worth the time.
    I've had good success in plastics by drilling a pilot hole and very gently screwing a standoff into that hole using a small socket.
  6. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    You can chuck the tap into a drill and tap it that way. I do it all the time, even as close a .5mm from the edge.
  7. Parge
    16 Jul 2010
    Hi guys,
    I'm also doing the above. Could someone link me to the exact drill bit and tap I'll need. I'm an absolute novice and its all very confusing. I'm drilling into 1.2mm steel.
  8. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Model fixings do a set of 3 taps (Taper - second - bottom)
    M3 0.5 Set of 3 Taps + Drill MF-T30S3D £10.55
    For tapping M3 I would use a 2.5mm drill bit (also available from modelfixings for 80p)
    Personally if I was going to be doing this I would buy the tap set and then a few extra drill bits.
    Tapping Info
    (taken from model fixings)
    Taper Tap
    This is the initial tap used to start the tapping process for a female thread. They have a long lead in of 7 to 10 threads. Also often referred to as '1st Tap'. For softer materials it is often possible to go straight to a second tap.
    Second Tap
    As the name suggests, this is used after the taper tap to produce the full thread in 'through holes' or 'blind' holes where the thread does not need to go close to the bottom of the hole. Sometimes referred to as 'intermediate taps'
    Bottom Tap
    Used where the thread is required to extend near to the bottom of a blind hole. Often termed a 'plug' tap in the UK.
    Simple Tapping Guide
    (taken and edited from ehow)
    Step 1
    Drill the correct sized hole into the plastic to the right depth.
    Step 2
    Place the end of the tap into the drilled hole, making sure it is 90 degrees to the surface of the plastic.
    Step 3 (important if you want a clean thread)
    Turn the tap handle slowly clockwise 1/4 turn. Then turn it counterclockwise--this is to remove plastic shavings. Turn the tap another clockwise 1/4 turn before turning it counterclockwise again. Continue in this fashion until the entire hole has been threaded. Finally, remove the tap by turning it counterclockwise and wipe away any plastic shavings from around the hole entrance.
    NB: For plastics lubrication is not essential but I would highly recommend using some! you can buy specialist tapping grease but WD40 works fairly well I've even heard of people using beeswax, olive oil or butter!
    PS, remember to clean your taps once you finish each thread, a firm tooth brush can be great for this.
    If tapping is not for you, it doesnt yeild the desiered result or you want something that will not wear out through intense usage then there is the option of threaded inserts
    These can be heated and then pressed into a pilot hole giving a secure long term fixing.
    Hope this helps you guys :)
  9. Parge
    16 Jul 2010
    Cool! Thanks very much! Will that work for metal too?
  10. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    yes Parge but use a thick to medium depending on material cutting oil or something like wd40
