Build Advice Which matx mobo to choose for overclocking??
Discussion in 'Hardware' started by Nealieboyee, 22 Aug 2010.
  1. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    Hi guys,
    I started a thread a few weeks ago about parts suggestions for an htpc. I’ve since decided not to stick with mini-itx, and gone for matx, mainly because the cpu placement on the Gigabyte H55N-USB3 is really bad. Finding a cooler to fit that has been a nightmare.
    So my choices as far as mobo go are:
    1. Gigabyte H55M-USB3
    2. Gigabyte H55M-UD2H
    Or anything you can recommend?
    I’ll be using a G6950 or i3-530, depending on the budget.
    It needs to be a good overclocker, and from what ive heard, the second option is, but I’ve also heard that people had problems with bad BIOS, bad memory compatibility, and generally bad batches.
    Budget for mobo is anything under £82.
    Thanks in advance
    Neal
  2. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    For overclocked micro-ATX builds, the Gigabyte boards are the ones of choice. The H55M-UDH2H you listed is going to be your best choice, if you need USB 3.0, then just buy the other board. Both are fantastic overclockers.
  3. BiotecVirus
    BiotecVirus Everything should use Torx Screws
    10 Jun 2010
    i'd probally go for the Gigabyte H55M-UD2H. and on another note processor wise go for the G6950, much more overclockable.
  4. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    As has been said, the H55M-UD2H and theG6950 is an overclocking mix made on the thighs of pristine Angels.
  5. docodine
    docodine killed a guy once
    10 Feb 2007
    It's a shame that there aren't any new DFI LanParty Jrs..
  6. Nealieboyee
    14 Aug 2009
    @Zinfandel and BiotecVirus
    Yes i saw the Bit-tech review of the both the board and the cpu. 4.6Ghz isn't bad at all!!!
    But what DECENT hsf is short enough to fit this board in a 140mm case? I've looked at the scythe ninja mini and a bunch of others, but only the ninja is short enough. Some others got bad reviews.
    lol no H50 suggestions please.
  7. docodine
    10 Feb 2007
  8. Bakes
    Bakes What's a Dremel?
    4 Jun 2010
    Asus Rampage III gene?
  9. SPNKR
    SPNKR Pretty Good Kid
    22 Feb 2010
    That is an x58 board, out of his budget, and won't fit his cpu.
  10. Bakes
    4 Jun 2010
    forgive me, I didn't read all of his post.
  11. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    I find reading posts before giving advice helps you not reccomend absolutely the worse product possible for what has been requested!
  12. Nealieboyee
    14 Aug 2009
    Thanks for the answers guys.
    @docodine
    You sir, are a god among men! Thanks, looks like the big shuriken will fit.
    Hows the performance of it?
  13. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    I have a couple of Scythe Mini Ninja's. One of them is running on my NAS with a slow 80mm fan attached and keeps it very cool. It is a Celeron E1500 though so it is never going to get hot.
    I found that running the Mini Ninja on a S775 E6600 @ 3.2GHz would allow the CPU to get too hot in a bad airflow case. I replaced it with an Arctic Cooling Freezer 7 Pro.
    It is my opinion that the Mini Ninja has an upper limit of heat transference that will not be high enough for an overclocked G6950 or similar.
    So it is +1 on the Big Shuriken then.
    A couple of reviews I found:
    http://www.atomicmpc.com.au/Review/163021,scythe-big-shuriken.aspx
    http://www.hardwaresecrets.com/article/842
