Build Advice Best motherboard for i5?
Discussion in 'Hardware' started by Ch33sefiend, 26 Nov 2012.
  1. Ch33sefiend
    Ch33sefiend What's a Dremel?
    20 Jan 2010
    Hey guys, just a quick question around a potential build I'm thinking of - I'm looking to build up an i5 with 16 gig ram (just because its so damn cheap) and a decent motherboard - the problem is I'm having a little bit of trouble deciding on the motherboard - price is a key part of the build but I don't want to skimp on overclocking etc.
    Does anybody have any ideas?
    Thanks in advance! :thumb:
  2. tp148
    tp148 Minimodder
    17 Nov 2009
    Do you actually need 16GB RAM?
    Also what are you using the rig for?
    Are you limited to a certain form factor?
    You said price is key so what is your budget?
  3. adzc1987
    adzc1987 Minimodder
    19 May 2011
    As above might be an idea to state specifically what you plan on doing.
    Im gonna upgrade my MOBO/CPU soon.
    I have decided on this mobo, i read a review on the i5 3750K with that MOBO and it scored well in OC.
  4. tp148
    tp148 Minimodder
    17 Nov 2009
    Ye the Z77-D3H is very highly regarded for OCing.
    Ch33sefiend, if you're gaming you don't need more than 8GB RAM tbh, if you're doing video editing, or other demanding stuff then you might be able to justify it
  5. Ch33sefiend
    20 Jan 2010
    Sorry about quick post (was on lunch) - the budget in mind will be probably no more than £100 ish, not really limited to any particular form factor as I've got a pretty big case but will probably want to steer clear of the mini stuff as I have lots of room for air etc etc.
    Budget is probably the main thing for me - as I will be spending around £150 for the CPU I'll want to limit the budget for the motherboard as much as possible (within reason, of course!). I'd imagine around £100ish.
    The main reason for the 16gig ram is that I encode a lot of movies.
    The machine will mainly be for gaming / video encoding.
    Hope that helps!! :D
  6. Ch33sefiend
    20 Jan 2010
    Oooh, very cheap! Thanks for the recommendation :)
  7. tp148
    tp148 Minimodder
    17 Nov 2009
    Credit to adzc1987 for reccommendation!
    In that case, defo take advantage of cheap RAM! i hate seeing the price of 8GB kits after paying £70+ for mine a while ago :(
  8. Ch33sefiend
    20 Jan 2010
    Haha, I have good ol' DDR2 which cost around £50 for 2gig.... prices of RAM make me sick now... :D
  9. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    The GA-Z77-D3H is a good choice; no issues whatsoever with overclocking to 4.5GHz. I also have 16GB of RAM.
  10. RocketPotato
    RocketPotato What's a Dremel?
    4 Sep 2012
    The P8Z77-V LX gets great reviews, also it recently got a decent price reduction!
  11. Ch33sefiend
    20 Jan 2010
    Cheers guys, got a good idea now - just gotta budget up :)
  12. adzc1987
    adzc1987 Minimodder
    19 May 2011
    Try an steal my glory eh! *shakes fist!
