Watercooling Your worst watercooling mistake? Any advice for WCing n00bs?
Discussion in 'Hardware' started by Parge, 3 Apr 2012.
  1. Parge
    16 Jul 2010
    Not sure if any of you are following my build log, but since I have some spare time over the long weekend, I’m going to be assembling my first watercooled build. I’ve leak tested all the main parts of the loop (CPU Block, Rad, Res etc etc) and all seems fine.
    Now, I know this is a very general question, but I want to get it right first time, so, I was wondering; is there any advice you’d give me about assembling a WC rig? What are the biggest mistakes you guys have made?
    I’m using compression fittings and ½” ID black tubing, with De-Ionized water and a silver kill coil. I have a fillport on the top of the Res, and a drain port at the bottom of the loop.
  2. mrMonkeyChunks
    mrMonkeyChunks EVGA Cheesecake
    4 Mar 2012
    Make sure the drain port is closed before filling the loop :wallbash:
  3. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    Make sure you don't over tighten the barb's after the tube is fitted, because if you do you have to cut the tube.
  4. Mongoose132
    Mongoose132 Duckmad
    23 Aug 2007
    Done that too, felt so stupid when I saw :D
  5. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Take your time and plan. I miscalculated the size of my res in my case and it screwed my plans up...
  6. Guest-23315
    Guest-23315 Guest
    Just take your time and triple check everything.. and remember air always wants to go up, water down..
    And dont use coloured liquids :lol:
    In all seriousness, just use common sense, leak test properly, and if youre unsure, ask advice, no matter how stupid you might think it is, thats what this community is here for :thumb:
  7. samkiller42
    25 Apr 2006
    When attaching water blocks to gpu's/cpu's, don't over tighten, or you may crush something, like i did. Ram Chips on 8800GTX's are required for the card to 'Work'
    Sam
  8. Wing Zero
    Wing Zero Ita-sha owner
    28 Apr 2010
    when tubing. draw out a diagram of where you want your tubing to go. check twice, cut once on tubing. also, make sure you connect everything up before you switch on, don't do what i did once and somehow connect your blocks to a rad, then forget to connect a pump in there somewhere
  9. Apocalypso
    Apocalypso Fully armed and operational.
    15 Sep 2007
    Forgetting to put the clamps on the hose before I ran a leak test, forgetting to jump the psu and seeing water pouring over my new graphics card whilst it had a current running through it.
  10. Parge
    16 Jul 2010
    Oh jeeze. Any of the above could be me. I'm going to have to go real slow.
    I've already test fitted everything in the case and it all seems to fit, so at least that one is out of the way. I'm also just using de-ionised water for my first WC rig, Keep It Simple Stupid.
  11. digitaldunc
    digitaldunc What's a Dremel?
    4 Oct 2010
    Leak test properly -- overnight ideally.
    If you're using barbs, don't over tighten as you can split or cut the hose wall.
    Careful when screwing in fittings to acrylic, you can crack it if you're over zealous.
  12. TobletDanillio
    TobletDanillio Minimodder
    7 Jan 2012
    may seem stupid but how do you to a leak test?
  13. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    You pack your cabinet with towels and clingprack so if theres a leak it doesn't shower your components. Then you jump-start your PC with the paperclip method (Google it) and then you just wait and see if there's any leaks
  14. debs3759
    debs3759 Was that a warranty I just broke?
    10 Oct 2011
    As others have said, leak test your loop before you power up the system.
  15. TobletDanillio
    7 Jan 2012
    I know how to jump start a power supply do it at work everyday.
    Would it be a good idea to put power to the pump and turn it on its side?
  16. Picarro
    9 Jun 2009
    Well after you have ensured that your computer it leak-less you fill it up to the brim, and jostle it around to make sure all of the air in the radiators and blocks escapes to the reservoir. Then you fill it again and rinse and repeat until no more bubbles are present in the system.
  17. TobletDanillio
    7 Jan 2012
    i meant to leak test it lol but ^ I have read that before ^
  18. Tangster
    23 May 2009
    Remember to reassemble things with the o-rings inside, not on the desk.
  19. digitaldunc
    4 Oct 2010
    Lets be clear here, you're shorting out the PSU so you can apply power to the pump and only the pump. System is assembled with the minimum amount of components required so your loop and blocks are in place. *This* is leak testing.
    No, the system is totally filled and bled during leak testing -- there's no use testing with a half filled loop as you're not simulating the same conditions that will exist during use.
  20. TobletDanillio
    7 Jan 2012
    ok where should I buy my gear from?
