So today we've uploaded the SECOND of our SIX office build episodes! We've got the Candy Cane Build for you today, built in the Raijintek Asterion case, and we've customised the majority of the components! A full list of all components we used will be left below Check out these pictures of the beginning, middle and end of us building! Where to watch our build!? The video link - https://youtu.be/1h1O9pMvG6Q PRODUCTS USED: ⭐️ Intel 3930K http://amzn.to/2naQ8rO ⭐️ Asus X79 Rampage U Motherboard http://amzn.to/2oCQB5R ⭐️ Noiseblocker Fan 120mm http://amzn.to/2nb39Sa ⭐️ XSPC 360mm Radiator http://amzn.to/2o9NwK0 ⭐️ XSPC 120mm Radiator http://amzn.to/2naZS5g ⭐️ CableMod Red & Black Cables http://amzn.to/2naUC1u ⭐️ Kingston DDR3 32GB Hyper Beast http://amzn.to/2nEed5r ⭐️ Corsair RM 850 PSU http://amzn.to/2oCWU9H ⭐️ Akasa Vegas RGB http://amzn.to/2p0Qgqh ⭐️ Akasa Sata Cable http://amzn.to/2p0Rstw ⭐️ Raijintek Asterion Computer Case http://amzn.to/2nK8UlR ⭐️ EK CPU WaterBlock http://amzn.to/2oD1u7J ⭐️ EK GPU Water Block (EOL: Not Available Anymore) ⭐️ BitsPower Reservoir http://amzn.to/2p0ZlPI ⭐️ Asus GTX 680 CPU - overclocked http://amzn.to/2nbkdr1 ⭐️ BitsPower PETG Tubing http://amzn.to/2p1flRP ⭐️ Mayhems Nano Fluid http://amzn.to/2nXK8jd ⭐️ Mayhems H2O http://amzn.to/2nY30Pa ⭐️ EK White 12mm Compression Fittings http://amzn.to/2p1hOeY ⭐️ Intel 120 GB SSD http://amzn.to/2nKgUDz ⭐️ Intel 240 GB SSD http://amzn.to/2nXNVNe ⭐️ Western Digital 1TB Drive http://amzn.to/2p1hbSU ⭐️ Western Digital 2TB Drive http://amzn.to/2naTJpE ⭐️ Samsung 1TB Hard Drive http://amzn.to/2oIyY1M ⭐️ Thermotech Pump http://amzn.to/2p1eGzF TOOLS USED: Monsoon - Hardline Pro Mandrel Kit http://amzn.to/2ngESFi Monsoon - Hardline Pro Cutting Kit http://amzn.to/2oaFVeK Dremel - Multi-Tool http://amzn.to/2njdcAz Dremel - Cutting Disks http://amzn.to/2ngvzW8 Dremel - Drill Bits http://amzn.to/2oaMqyz Dremel - 100pcs Mixed Accessory Kit http://amzn.to/2oaCQeO Rolson - Offset Screwdriver Set http://amzn.to/2ngNMTt Earlex - Heat Gun http://amzn.to/2oaq4Ns Big thank you to 'Cars With Scars' for spraying our case! - http://www.carswithscars.co.uk
I am interested about your build but, don't know why? I cannot access the video, can you provide a link to it, or post some pics of your work pls?
Hi Kim! Of course, I'm so sorry that you can't access the video. Try this link! And if not, try this... https://youtu.be/1h1O9pMvG6Q If you refresh the thread, you should now also see a full album of build pictures! - Elliemay | MxdOut
For 'tube links, just post the code in the link after the / -Wait... I can't see it either 'cuz I have flash disabled.
yeah, very nice work...I like this color theme, and I apologise for my complain...it was my side finally, it wasn't my flash :d but it turns out my brandwidth collapsed unexpectedly yesterday so sorry.
