Cases Which Cases Big n Easy for Open WaterCooling Install Incl. Radiator Enclosing?
Discussion in 'Hardware' started by chap, 22 Aug 2011.
  1. chap
    chap What's a Dremel?
    4 Jun 2011
    List 1
    CIT 3015DR Black/Red Midi Case with 450W PSU
    ASUS TA-8J1 Black Midi Case No PSU
    ASUS TA-K12 Black Midi Tower Case No PSU
    CIT 2206 Black Midi Case with 500W PSU
    CIT 3015DB Black/Blue Midi Case with 450W PSU
    CIT 3016DG Black/Green Midi Case with 450W PSU
    CIT 3016DR Black/Red Midi Case with 450W PSU
    ASUS TA-9L1 Black Midi Case No PSU
    Cooler Master Elite 330 Black - Silver Midi Case No Psu RC-330-KKN1-GP
    INWIN Griffin Midi Tower Gaming Case with 22cm Fan No PSU
    NZXT Beta EVO Black Midi Case No Psu
    CiT Venus Midi Tower Case with 2 x Blue LED Fans & LED Display
    Cooler Master Elite 334 Nvidia Edition Black Case + Window
    NZXT M59 Midi Tower Case No Psu M59-001BK
    Asus TA-M11 Black Midi Tower Case No PSU
    NZXT Lexa S Black Midi Tower No Psu LEXS-001BK
    NZXT Vulcan Micro ATX Black Case No Psu VULC-001BK
    Inwin Inwin Dragon Slayer Gaming Case No Psu
    NZXT Hades Black Midi Case Dual 200mm Fan No PSU
    INWIN Android Midi Tower Gaming Chassis 22cm Fan
  2. chap
    4 Jun 2011
    List 2
    INWIN Dragon Slayer Gaming Case No Psu
    Powercool Powercool Terminator Midi Gaming Chassis with Card Reader No PSU
    Inwin Hush Black Case No Psu HU-001B
    Cooler Master Sileo 500 Black Silent Case (No PSU) RC-500-KKN1-GP
    NZXT Tempest EVO Midi Tower Case No PSU
    Cooler Master HAF 922 Black ATX Case RC-922M-KKN1-GP
    INWIN Ironclad Full Tower Gaming Chassis E-ATX 22cm LED Fan
  3. chap
    4 Jun 2011
    Should I ignore the 'Midi' cases and focus on the Full Tower?
  4. chap
    4 Jun 2011
    Some prefer the Cooler Master HAF series, thus is this Cooler Master HAF 922 Black ATX Case RC-922M-KKN1-GP suitable or should it be the HAF 932?
  5. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    What do you mean by open watercooling install ? What is you watercooling requirements (size and number of rad, etc.) ? What is your budget ?
  6. chap
    4 Jun 2011
    Purchase a budget non-water cooled system with a big n easy case and find someone to put non-closed watercooling.
  7. David
    7 Apr 2009
    You mean you don't want a simple sealed unit cooler like the Corsair H70 etc...?
  8. chap
    4 Jun 2011
    Absolutely I am not interested in them as they are closed, self-contained though closed for putting chosen coolant.
  9. GuilleAcoustic
    26 Nov 2010
    Silverstone TJ07
    Coolermaster Cosmos S
    Watercooling out of the box with no dremel :thumb:
    Lian-li offer spare top panel for their cases that allow top mounted rad
  10. David
    7 Apr 2009
    Xigmatek Elysium too
  11. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    Depends what rad's etc you want..as the NZXT beta evo might suffice...i have one for my server and im pretty sure its w/c capable
  12. chap
    4 Jun 2011
    Sorry I cannot have them as the seller's case upgrade options has others not them.
  13. chap
    4 Jun 2011
  14. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Thats the way you want to go if you want to do simple hassle free watercooling. Masses of space for anything. There's many pics in my thread (in sig) which is also a must if your new to watercooling...
  15. chap
    4 Jun 2011
  16. chap
    4 Jun 2011
    "....However, one feature in particular is near impossible to live up to: external dual radiator support. Just because a case has two grommets to allow watercooling tubes through does not mean it supports two radiators. If someone really wanted to constrain themselves, they could attach radiators to the side, top, or rear fan grills. Attaching radiators there isn't really 'radiator support' though; it is simply feature duality, and almost quashes the idea that this can be a watercooling case out of the box.... "
    http://www.thebestcasescenario.com/frontpage/?q=node/413&page=0,5
  17. chap
    4 Jun 2011
  18. Jipa
    5 Feb 2004
    Please, learn to use the edit-button instead of spamming five messages in a row.
    Maybe instead of asking us about the case, you should ask the "someone" who's going to install the water cooling? With the lack of specs, it's impossible for us to really tell the best case. And if someone's going to remove the warranty on those parts anyway, why not just pay him to also build the rig in the first place?
    EDIT: All in all so far this thread is completely incomprehensible, from what I could understand you are buying a budget-build pre-made somewhere (why?) which you want someone to watercool (why?) and sealed systems are out of question (why?). What are the specs, how many radiators you need, etc. MORE DETAILS. just think if over and post one message that actually contains the required specs..
  19. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    I can't even make sense of this thread...
    For a 'cheap' case, get the Elysium, for something a bit more, the 800D or TJ07.
  20. David
    7 Apr 2009
    You might manage a 240mm rad in the roof. Remove the drive cage and you'll get a chunky 120mm in there too.
    Looks a bit tight though - not an awful lot of room between the roof and the motherboard.
