Hello Bit-Tech ! After more than one year since my last project based on an Apple Cube, I started another one bigger based this time on the well-known Apple PowerMac G5 ! If we like or not the brand with an apple, I think the design of this case leaves no one indifferent ! Let's the party begin !
First Update ! I started on the front of the case, by creating a new entry for a slot-in drive, it took me a lot of time for this but I'm quite happy with the result First aff all, some line on autocad, to be sure of what I'll do ! then the drawing somes holes with some little files result cut temporary support of the new slot and, the cut on the case installation of the new slot on the case and gluing with the epoxy and, drill all the little holes with the help of a guide When it's done, we take off all the parts to clean them and we put it all together with some epoxy mastic when it's dry, we sand and again some drilling to unclog holes filled product little spray paint to have an idea of the result this part is finish !! All your comments are welcome ! The next update will be on the front panel Stay around !
Nice work. Continuing the holes to make it look OEM is always a good plan with these cases. Most others just bolt stuff to the front/back.
Second Update !! This time, it's about the integration of a USB 3.0 frontpanel . As I done for the slot, I begin with some lines on Autocad then some drawing and cutting and I cut the case the two parts ready to be assembled after some sanding drilling some painting to check the result then we continue on the support of the frontpanel, my goal was to make it invisible from the outside of the case, so it take lot of time and holes ! first, find some space to drill holes ont the frontpanel the same on an aluminum corner after many steps this is what I got, I think this part is not so clean than the other, because I redrilled all the holes in 3,5mm (instead of 3,0mm) to try to hide this support. then we glue the support with an exoxy glue and this is the result after some finishing The next update will be about the integration of the lian li hotswap rack ! Stay around
Finally someone who respects the holeyness p) of this case and doesn't just cut huge chunks out of it. Great work!
Glorious work. I love how much work you have put into making this full retooling almost unnoticeable. @Nexxo- Ow...
Now this is what a G5 mod is supposed to be! I've never seen anyone take such an approach this far and I sure hope you'll have the strength to pull out all the stops all the way. I'll definitely be watching this one. Darkened
thanks a lot friends for all your kind comments, it really helps me to keep my motivation !! Update!! SSD's @home !! Admire what the Santa Claus brought to me !! Two beautiful Kingston's drives SSD HyperX 3k Ok my rabbits, let me take a few more pictures of you ! Their finition is just perfect, these ssd got a look so classy while remaining sober, they smell good the quality as usual !! It will be very hard to wait until the project is finished ! Stay around !
Hi here ! I'll probably post this afternoon some pictures of the psu during unboxing and some more progress with the hotswap rack !!
Update !!! PSU @home !! The superb P-760 Hybrid by Seasonic has arrived safely, and visibly the travel was good ! Let's start the show !! jolie assortiment de câble et la voilà... vraiment bien protégé dans sa jolie pochette en velour tout doux [:bakk3] and one last picture of the family The PSU and the packing reflects the quality that we know of Seasonic ! Next update will be about the integration of the hotswap rack ! Bye!!
Great work there. Shows a lot of respect for the original design, which is what mods should be about IMO.
Update !! about the installation of the HDD rack first, remove all I don't need ! for the integration I reversed the bottom with the top Some M4 tapping then the cut of the separating plate Little Picture of all the parts and, installation of all this parts That's all ! Next update will be about the creation of the support for the 2x140 mm Prolimatech's fans !!
