Scratch Build – In Progress Worklog: JP[μ]
Discussion in 'Project Logs' started by JaPeMo, 29 Jan 2016.
  1. JaPeMo
    JaPeMo What's a Dremel?
    31 Aug 2013
    Hi!!!
    After looking for a new case with a lot of frustate ideas, I go to make and build my case.
    I like some cases but all have some problem or don't like some point. Looking in Google I look EK Vulture, and I decided built case like this with my modifications.
    Now I'm drawing in CAD program...
    First I put components with my taste.
    Option A
    Option B
    Problems...
    Ram waterblock do interference with push-pull option...
    I decide built Option A and I started yerteday to draw some sketches for frontal case...
    Now, some 3D pieces modelings with frontal option decided.
    Front cover (Acetal 7 and 10 mm with frost white logo):
    Back plate cover (aluminium 2 or 3 mm):
    And last, sktech for mount:
    Tomorrow I will draw back case.
    Kind regards...
  2. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Subbed.
  3. JaPeMo
    31 Aug 2013
    I'm still working on parts , settings , etc ... it is no small feat and design all the pieces fit , but above all, make sure everything is fine, since once made ​​the piece can not go back.
    In another topic. As you know I'll put the inverted plate , that is, rotated 180 degrees, my question is related to the block RL . In theory having an input and an output by default and a position on the motherboard , either . So far so perfect, but in this case the plate is rotated , if the block is placed in normal position ( as a plaque in his normal position and not rotated ) , I'll have some cooling problem ?. So you understand , well , block 180 turned over the plate, as if the block put it upside down on a plate normally installed.
    Kind regards
  4. JaPeMo
    31 Aug 2013
    Good evening or good morning could say almost ...
    Now I have almost finished 3D, missing lids and details of grommet and rear fan ...
    Tomorrow I hope to have it finished and send it to the budget ...
  5. JaPeMo
    31 Aug 2013
    3D model finished...
    Regards
  6. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Subbed!
  7. JaPeMo
    31 Aug 2013
    Hi friends
    Today I received somes budgets.... only letters and front acetal between 300-400€.... without aluminium...
    Perhap I bought case to do my project with some modifications. This weekend I will have all:
    Case...
    GPU...
    Waterblock...
    See you soon...
  8. JaPeMo
    31 Aug 2013
    Hi!!!
    New component arrived!!!
    OMG!!!! Waterblock is a lot of bigger!!! FANTASTIC!!!
    LOL!!! This is the bigger GPU than I look at the moment...
    And case, pretty, pretty, pretty...
    After I presented GPU to take dimensions...
    I have free 103mm fron GPU to plate to install reservoir with 60mm diameter and 45mm thick rad... What will happen?...
    My idea is don't moddify case except do better air cooling or extra personalized panels
    Regards!!!
  9. JaPeMo
    31 Aug 2013
    Good night or maybe good morning too
    After intense night...
    And the last, after UPDATE to last BIOS (0502) and I overclock micro to 4250MHZ with the options in AUTO... After install W10, drivers and...
    Now I go to sleep some hours and after go to work... Hard day and a lot of cofees...
    Regards!!!! :thumb:
  10. JaPeMo
    31 Aug 2013
    Hi friends!!!
    Before I give new developments I have to thank the effort, patience and support they have given me from
    On the other hand, more packages arrived yesterday and today another two. With this, I can really having almost everything to present and organize the space ... Start!!!.
    From Amazon, the tool to bend the tube ...
    And from E22, samples of sleeve ...
    Since Highflow.nl, a regular store my purchases and which has on occasion sponsor, some samples of sleeve, a top Koolance COV-RP450 (Rev 2.1) and the reservoir body diameter 60mm and 200mm high ...
    And they rolled them together are so, I love ...
    Go to the Top and reservoir...
    And weekend near...
  11. JaPeMo
    31 Aug 2013
  12. JaPeMo
    31 Aug 2013
    Hi
    Today I continued dismount case and I found this...
    After I presented and installed components to look free space and position. In the first option. I installed reservoir in vertical position
    Second option, I don't like much with reservoir in horizontal...
    After, I installed grills
    Now, I changed ilumination panel with RGB led strip...
    This is all for the moment...
  13. JaPeMo
    31 Aug 2013
    Hi, updates with waterblocks!!!
    I decided install serial backplate, I love it
    and RAM
    All waterblocks...
    GO!!! GO!!! GO!!!
  14. JaPeMo
    31 Aug 2013
    Good night friends.
    After a while on Saturday and another little while today I show progress.
    The blocks in the MB and RAM
    We spent the copper chromed...
    My first tube ...
    It seems easy, right ... for the next 2 have led me all afternoon, it's not like acrylic, copper pipe involves not a step up, but 2 in a ladder ...
    And the last, with double curve provided, I sweated blood to finger ... not sting like scabies ...
    When I say that is 2 steps, I mean this ...
    I wasted tube, when you're wrong, there's no turning back. I have left, are supposed to be easier, but until it touches wood finish before starting it ...
    Regards!!!
  15. JaPeMo
    31 Aug 2013
    Hi!!!
    Today my dremel had broken and I built manual plate to support radiator and fans.
    Tomorrow I will received more components to continue...
    Regards!!!!
    Enviado desde mi HTC One mediante Tapatalk
  16. JaPeMo
    31 Aug 2013
    Hi!!!
    Yesterday I received some components to change and install. New reservoir from Aquacomputer, pump from EK, Top pump from Aquacomputer, heatpipes for pump from EK and last flow indicator from barrows
    And now, I'm working in plate to fix rad and fans to case...
    Now I go to continue working....
  17. JaPeMo
    31 Aug 2013
    Hi again!!!
    Updates from this evening...
    First I presented reservoir and pump...
    Yesterday I bought polish and I used to do good finish to acryilic side...
    After, I installed fans and rad in support
    And last, in the case...
    I inserted a piece of pipe to look aligment..
    After studied some positions and circuit, I decided to do a new hole in reservoir...
    After polish, I installed for don't do cyclone... and fittings...
    Tomorrow I want build support for reservoir, pump and filter...
    Regards!!!
  18. JaPeMo
    31 Aug 2013
    Hi
    I was finish the reservoir support. It wasn't perfect, but I don't want spend much time, maybe I will do some tick to do good quality. It is very solid, more than I thought.
    I gone fast and crash...
    When I finished support I know that I done bad drills with wrong position, I do new drills and correct this without problems. Now are reversible...
    Now, I used fittings and adapters but I have pipe to install and look wich is more beautifull
    Regards!!!
  19. Reapervon
    Reapervon What's a Dremel?
    17 Aug 2014
    Subbed!
  20. IWantAnA2
    IWantAnA2 What's a Dremel?
    7 Mar 2015
    That's quality workmanship on that reservoir support. How'd you get such precise cuts by hand?
    Subscribed!
