Hardware Noctua NH-L12 review
Discussion in 'Article Discussion' started by brumgrunt, 17 Dec 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. Parge
    16 Jul 2010
    "It's been nearly three years since we last saw a cooler from Australian manufacturer Noctua"
    It does get pretty hot in Oz, I guess that explains why they make such good coolers.
  3. rici1241
    rici1241 Minimodder
    4 Jan 2011
    Noctua is Austrian, not Australian.
    They do make some very good cooler's, and quite ones.
  4. Parge
    16 Jul 2010
    Yep :thumb:
  5. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Bit-tech in proof-reading shocker! Do you guys not proof-read at all? ;)
  6. TheDodoKiller
    TheDodoKiller Minimodder
    23 Oct 2011
    They're partnered with that other Australian country that makes motorbikes, KTM.
  7. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    Haha, oh dear, my bad :p fixed now, thanks!
  8. mikeyandrewb
    mikeyandrewb What's a Dremel?
    31 Oct 2011
    Man that's ugly....
  9. SMIFFYDUDE
    SMIFFYDUDE Supermodders on my D
    22 Apr 2009
    Why do they persist with that horrible colour scheme?
  10. Parge
    16 Jul 2010
    I know. Its absolutely rank. Do they not understand that aesthetics are important!?
  11. rici1241
    rici1241 Minimodder
    4 Jan 2011
    I think there reasoning is that it makes them stand out from the competition, and be more recognisable.
    It certainly does that, but its hideous.
  12. wafflesomd
    wafflesomd What's a Dremel?
    22 Oct 2005
    I like the color scheme. Makes the product feel more professional as it doesn't rely on flashy plastic parts like say, a cooler master v8.
  13. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    Logic fail; the fan itself is the ugly part due to the colour-nearly all fans are made of plastic, yet most brands are sensible enough to stick with black, white, silver or clear for the frame and blades as they look nicer and match most cases. Light brown matches nowt ( company spiel is that it reflects their eco friendly attitude with its earthly colours... ).
  14. Eiffie
    Eiffie What's a Dremel?
    11 Oct 2010
    The colors don't bother me one bit, I sorta wish more companies went with this style, it gives it a bit of a retro feel, like something I might find buried in an old office somewhere. :)
  15. Adnoctum
    Adnoctum Kill_All_Humans
    27 Apr 2008
    How does it cope with the odd (and inconvenient) socket placement on S1155 ITX boards?
    If the information that the retention mechanism doesn't require a backplate is important, then this is doubly so. Does it fit on a S1155 ITX board with a graphics card?
  16. Benihana
    Benihana What's a Dremel?
    6 Feb 2009
    I'm wondering if the other components were low enough, could you use the larger 120mm fan underneath instead of the 92mm? I'm building an HTPC with the Silverstone GD04 and the cooler height is 70mm, so this seems like a good bet, but Noctua also have a 140mm low profile cooler...
  17. Benihana
    6 Feb 2009
    In case anyone else wondered about my question:
    "Is it possible to install the supplied NF-F12 or other 120mm fans underneath the fin stack?
    The NF-B9 92mm fan is used underneath the fin stack because it gives easy access to the mounting screws and sits within the 95x95mm (Intel) and 96x114mm (AMD) keep-out zones, thus providing full compatibility with standard height RAM and chipset/VRM heatsinks. In principle, it is also possible to put the supplied NF-F12 120mm fan underneath the fin stack instead, but in many cases, this setup will cause compatibility issues with RAM and/or chipset/VRM heatsinks. Similar issues are likely to arise with other 120mm fan models and in addition, some fans may be blocked by the mounting screws and/or block access to the screws. As a result, using 120mm fans underneath the fin stack may be possible in some cases, but is not officially supported."
    http://www.noctua.at/main.php?show=faqs&step=2&products_id=46&lng=en#13
  18. Dogbert666
    17 Jan 2010
    I can't say whether it will fit on every LGA1155 mini-ITX board, but it can fit on an Asus P8Z77-I Deluxe w/ a graphics card, for example.
  19. Adnoctum
    27 Apr 2008
    Not a good example, unfortunately, because that motherboard is one of the few S1155 mITX-sized boards that has the socket away from the PCIe slot.
    Compare the Asus P8Z77-I:
    To the Asrock Z77E-I:
    The layout of the Asrock is far, FAR more common in S1155 mITX motherboards, such as the one I have.
    Because of this inconvenient layout, the perfect Scythe Big Shuriken that I have sitting idle is looking for a home in some other flimsy excuse I can invent to spend money. My HSF needs something to do - that's a good excuse to build another system, right?
  20. Dogbert666
    17 Jan 2010
    Fair point. We have a Zotac Z77 wifi ITX board in the labs somewhere I think. If you want (and providing I have time/remember) then on Friday I can mount it (or attempt to)? No promises though :p
Tags: Add Tags
