Motherboards 3570K in a Asus Z68 pro/gene z
Discussion in 'Hardware' started by MrGumby, 19 May 2012.
  1. MrGumby
    MrGumby CPC 464 User
    27 Apr 2009
    Hi all. Going to be aiming for a 4.5-4.6 overclock on a 3570K in one of the above boards.
    Do you think i will run into any problems with compatibility? I ask because i have seen no reviews of ivybridge overclocking on z68.
    Oh and if your around Bindi your help would be much appreciated.
  2. Guest-16
    Guest-16 Guest
    Neither board comes with BIOS Flashback so you'll need a Sandy Bridge chip to upgrade the BIOS first. I don't know about overclocking sorry.
  3. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Just get a M5G as its the same price as the Gene-z...
  4. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    There is over 6ghz IB overclock on genez at hwbot.org. i made my small research after gigabyte multiplier story
    send from my BLADE via tapatalk
  5. TobyKing1982
    TobyKing1982 Minimodder
    23 Apr 2009
    I agree with bloody_pete, get the Asus M5G, I have that motherboard and it supports Ivybridge. I have the 3770k and I clocked that very easily to 4.6ghz so with a little more tweaking you might reach that speed.
  6. Guest-16
    Guest-16 Guest
    There should be a 7GHz..
    We've definitely had that in our lab.
  7. Bloody_Pete
    11 Aug 2008
    I want 7GHz!!! How many volts did that need?
  8. Guest-16
    Guest-16 Guest
    A lot ;)
    And it has a lot to do with chip binning. Most will only do 6-6.5.
    The 7GHz that leaked onto the next in March/April was actually ours on M5G from Feb when the OC guys were testing. Someone leaked our internal test doc :(:(
    Most Z68s will probably not go as far with Ivy than SB.
