Build Advice How do I get cable management this neat?
Discussion in 'Hardware' started by David164v8, 20 Apr 2014.
  1. David164v8
    David164v8 Minimodder
    29 Aug 2011
    I've been looking into a new PC lately, and I've decided the case I want is the Corsair 250D. Looking at this picture of it on their website, how does anyone ever get a PC to look so neat?
    My current PC is in a big tower case, it has generous cable routing holes and plenty of room. However mine still looks like a complete mess compared to this.
    So before I build my dream PC, what do I need to buy/do for my computer to look that great?
  2. SuperHans123
    SuperHans123 Multimodder
    27 Dec 2013
    Time, cable creativity, patience, cable ties, more advice.
  3. Teelzebub
    27 Nov 2009
    Practice and OCD
    G0UDG likes this.
  4. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    huge dose of OCD :D
  5. dancingbear84
    dancingbear84 error 404
    16 Oct 2010
    It takes a long time, and a lot of patience, don't expect to get results like that first time. I've cobbled together a few machines and have never been able to get anywhere close to that level of neatness.
    Sent from my Nexus 7 using Tapatalk
  6. Shirty
    18 Apr 1982
    Try using a PSU that is 20mm too deep with full length cables, in a case like mine:
    Not good for your OCD!
    G0UDG likes this.
  7. GeorgeK
    18 Sep 2010
    A silverstone modular PSU and the optional short cable set worked wonders for one of my ITX builds :)
  8. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Took me a while to get used to it, but it clicks one day then becomes straight forward.
  9. Shirty
    18 Apr 1982
    If Silverstone did a hybrid fan mode then I'd have gone for it. However, they don't and I wasn't happy with the noise output of the Strider Gold, so it went back along with the short cables :(
  10. David164v8
    29 Aug 2011
    Thanks for the advice, I'm looking into the Silverstone with short cables. Either than or a Corsair RM (that's the one with the fans that stop at low power draw, right?).
    I also would like to put some LED's in this build, although not really ostentatious ones. More like a subtle glow round the window, what do I buy for that?
  11. pete*
    pete* Something witty here.
    29 Apr 2009
  12. SuperHans123
    27 Dec 2013
    On the advice given I bought some led strips from EBAY and used double sided sticky foam as the sticky stuff on the back wasn't the best. It looks great.
  13. RagingMadman
    RagingMadman What's a Dremel?
    6 Oct 2012
    If you're having issues with your led strips sticking grab a stick of the cheapest super glue you can find and viola. I have 2 but Phoenix strips on the side of my case glued in place and have had no problems. As well as you can pull them right off the case if you don't want them anymore or to rearrange them. Just don't glue them to other cables etc...
  14. GeorgeK
    18 Sep 2010
    I have two strips - with one the double sided sticky stuff was fine and with the other it constantly fell off... For that one I drilled a couple of tiny holes in the case behind the front panel and used cable ties to hold it in place :thumb:
  15. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    Double sided tape or velcro can help to hold them down too!
  16. Deders
    Deders Modder
    14 Nov 2010
    Don't know if it's an issue with your setup or whether it is possible with your case, but can you position your hard drives so that the cables plug in out of sight?
  17. David164v8
    29 Aug 2011
    Are there any alternatives to the PP06 Silverstone short cables? It's a shame they can only be used on Silverstone PSU's.
  18. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    I'd concurr the above; Time, patience, cable ties galore, fully modular PSUs and a lot of OCD over getting it juuuust right.
  19. Guest-44432
    Guest-44432 Guest
    You can also cheat by using covers to hide the cable, like in your pic. ;)
    G0UDG likes this.
  20. Kovoet
    26 Aug 2009
    I found it very much a thing of what case I had. That is the beauty of the case I currently use
