A couple of the sides on my 4 x 2GB Crucial Ballistix Tactical Tracer have come away. This. Which makes putting even a little bit of pressure on when inserting the RAM very tricky. The sides are actually held on by rather naff double sided tape. Any suggestions as to a better fixative?
Scotch® - Double-Sided Mounting Tape you might have to trim to fit with sharp knife but sticks anything. That or a hot clue gun ??
This is the best double sided tape I use it for all kinds of things http://www.ebay.co.uk/itm/Mammoth-P...ial_Paint_Varnish_MJ&var=&hash=item4d036f8962
