Other Why images no work in posts for me?
Discussion in 'Tech Support' started by Drachnem, 18 Feb 2017.
  1. Drachnem
    Drachnem Minimodder
    15 Nov 2003
    I keep trying to post images but it just shows up as a broken image icon.
    Any advise?
  2. GeorgeK
    18 Sep 2010
    Where are you hosting the images?
  3. Drachnem
    Drachnem Minimodder
    15 Nov 2003
    I tried imgr and google.
  4. davido_labido
    davido_labido Your Alphacool Contact.
    11 Oct 2013
    can you post one so that I can look at it?
  5. Drachnem
    Drachnem Minimodder
    15 Nov 2003
    just tried a direct link, however it shows a HUGE image, and not a smaller version of it.
  6. davido_labido
    11 Oct 2013
    Ok, will check it out :)
  7. davido_labido
    11 Oct 2013
    Hmmm, seems imgur is the issue, if you use http://postimg.org/ it works fine
    I used these tags:
    PHP:
    [img]https://s10.postimg.org/amvjo9ypl/Erbke_Zt.jpg[/img]
  8. Drachnem
    Drachnem Minimodder
    15 Nov 2003
    Awesome i'll try that site then, thanks!
  9. GeorgeK
    18 Sep 2010
    When using imgur you need to use the direct link (the one ending in .Jpg or whatever file type youre using) and pick the large thumbnail option to not show such a massive pic
    Like this:
    The URL is only different to the one you tried in that it ends in L.JPG (L for large thumbnail)
  10. davido_labido
    11 Oct 2013
    I thought that too, but I couldn't see the other links as I haven't used it for ages and the Imgur site has changed.
    I found how to do it now though, a dropbox appears if you mouse over the top right and there are more options there :)
  11. GeorgeK
    18 Sep 2010
    Weird - I still get this page
