Cases Acrylic Case for watercooling?
Discussion in 'Hardware' started by chap, 3 Sep 2011.
  1. chap
    chap What's a Dremel?
    4 Jun 2011
  2. reggie50
    reggie50 Minimodder
    24 Apr 2009
    Not without serious modding. It only has 3 80mm fan mounts, all on separate panels. I'd say it's not suitable for any modern system.
  3. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    OH NO! Is this gonna be another thread where we asks you lots of questions chap? And you give us really obscure answers so we turn it into a spiderman thread?
    Do I dare ask (again!) what you are trying to water cool?
    And +1 to what reggie 50 said.
  4. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Acrylic cases are horrible. They break really easily and look horribly cheap and nasty (IMO). I'd avoid as muvh as possible, double so if your watercooling as thats a lot of weight your adding to a very weak case...
  5. Nexxo
    23 Oct 2001
    I'll just leave this here...
  6. Bloody_Pete
    11 Aug 2008
    Doesn't show any of the main watercooling bits though...
  7. Nexxo
    23 Oct 2001
    It shows that it is possible to build a very nice water-cooled PC around an acrylic case.
  8. chap
    4 Jun 2011
    Please say what is the standard template for case that needs watercooling installation?
  9. chap
    4 Jun 2011
    Probably sempron or athlon, they might be overclocked.
  10. chap
    4 Jun 2011
    Could it be toughened? This ebay seller is selling a watercooled system with an acrylic case choice http://tinyurl.com/ebay108 for 1199.99 pounds.
    The benefit is seeing the dust is not accumulating and components are functioning normally.
  11. noizdaemon666
    15 Jun 2010
    Athlon 64? Athlon II? Single, dual, triple or quad core? If it's a single core Sempron/Ahtlon then it's a bit like watercooling a squirrel. You can do it, but it's a pointless venture and won't give you anything other than a saturated sweatband.
    And the standard template for a watercooling case is the Xigmatek Elysium, or a Corsair 800D, or Silverstone TJ07.
  12. chap
    4 Jun 2011
    Sunbeam build acrylic cases. Not easy to get in Britain though.
  13. Bloody_Pete
    11 Aug 2008
    LOLs the first picture there is the one Nexxo posted!!! I didn't think is was for a customer, so that seems dodgy...
  14. chap
    4 Jun 2011
    Probably double core if athlon.
    Does standard template have the 'full tower' description?
  15. Bloody_Pete
    11 Aug 2008
    By 'standard template' he meant the cases most people use :)
  16. chap
    4 Jun 2011
    There is not much choice, thus is 'full tower' alternative better for modding the case?
  17. Bloody_Pete
    11 Aug 2008
    what do you mean?
  18. noizdaemon666
    15 Jun 2010
    It doesn't but by standard, I thought you meant what most people use. i.e. the actual definition of standard.
  19. chap
    4 Jun 2011
    Could 'full tower' cases not built for watercooling be modded easier than 'midi cases'?
  20. noizdaemon666
    15 Jun 2010
    You want to fit hardware into a case that sometimes doesn't fit in very large cases. How would a midi case be easier for watercooling? How? Just think about what you're saying.
