Build Advice New Gaming PC build advice - Budget £1400
Discussion in 'Hardware' started by margy, 13 Dec 2011.
  1. margy
    margy What's a Dremel?
    13 Dec 2011
    Hi guys,
    Im building a PC mainly for use with BF3 on ultra settings and MS Flight on ultra settings. With a £1400 Budget I am quite flexable but here is the spec I have come up with so far.
    Case: Coolmaster HAF X
    GPU: Asus 1500MB GTX 580
    Motherboard: Asus Maximus IV GENE-Z, Intel Z68, S 1155, DDR3, SATA III - 6Gb/s, RAID SATA, PCIe 2.0 (x16), VGA On Board, Micro ATX
    CPU: Intel Core i5 2500K Unlocked, S1155, Sndy Bridge, Quad, 3.3GHz, HD3000 IGP 850Mhz, 6MB Cache 95W Retail
    RAM: 16GB (4x4GB) Corsair Vengeance Blue DDR3 PC3-12800 (1600), Unbuffered, CAS 9-9-9-24, XMP, 1.50V
    SSD: 128GB SSD (internal)
    1TB External Disk drive
    Im relatively new to this so any advice would be appreciated!
    Monitor: Asus 27" LED 2ms refresh Grey to Grey
  2. Farting Bob
    Farting Bob What's a Dremel?
    21 Jan 2009
    Do you plan on using much Liquid Nitrgen in your cooling setup? If not then your wasting money on such an expensive motherboard. You could spend less than £100 and get a Z68 board that performs exactly the same with all the same features that you will actually need.
    Also, you wont need 16GB of RAM. 8GB (2x4GB) will be more than enough for any gaming rig in the next few years. RAM is cheap, but its still wasting money.
    That monitor, if im looking at the same one (a model number would be handy) then its a cheap TN panel screen. If you are that bothered by paying all that money for ultra-mega super settings in BF3 then get a better quality monitor. Something of the IPS variety.
    What SSD do you plan on? Prices and speed vary greatly from model to model. Crucial M4, Corsair force 3 and Force GT are excellent drives for their money.
    In summary: Get a cheaper board, less RAM. Spend that money on a better monitor and make sure you get a good SSD.
  3. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    I agree with Bob buddy...
    I'd go for a P67 board, either MSi or Asus and spend the extra on the 2600k. 4 more threads, more cache and more overclocking headroom. 16Gb ram is overkill too so if your budget is strict and you're on the limit, drop to 8. I'd also get a 1TB internal drive rather than an external. 128GB SSD fills up pretty quick if you install all your software and games. Install the OS and essential software and games to the SSD and then install all remaining non essentials to the internal HDD. Faster access times than a USB external drive of the same capacity.
    Other than that, a very capable machine. Dont forget to factor in a decent aftermarket CPU cooler!
    Sentinel.
  4. murraynt
    murraynt Modder
    6 Jun 2009
    I agree with the above.
    What screen is it exactally? Not a place you want to skimp.
  5. MSHunter
    MSHunter Minimodder
    24 Apr 2009
  6. margy
    13 Dec 2011
    Hi guys,
    Thanks for the replys. I agree that 16gb of RAM is overkill and in reality most of it will not be used.
    The monitor is this one: http://www.amazon.co.uk/VE278Q-Wide...XPQY/ref=sr_1_1?ie=UTF8&qid=1323813854&sr=8-1
    I already have it so changing would not be an option! Great advice on the motherboard. I will get one of the ones you guys have recommended!
    When looking at SSD drives which would you recommend? I havent really looked the actual model yet as I thought they were all pretty similar. Im trying to keep price to a minimum for the whole set up and I am aware that on several components marketing plays a massive part and you can pay way over what is actually necessary. But being a massive noob with this I dont have much clue where to start!
    Thanks again
  7. alanhannah
    alanhannah What's a Dremel?
    14 Sep 2011
    That's the perfect configuration for Gaming. If you enjoy playing games a lot, then you can choose for a Bigger size monitor.
  8. Bituser
    Bituser 64 Gigglebytes
    13 Aug 2011
    Bigger monitor? In my opinion a 27" is already huge. What power supply are you looking at using?
  9. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    You have a mATX motherboard and a full size ATX case. I would swap the HAF-X for a Silverstone TJ-08E.
  10. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Or swap the board for something like this :thumb:
  11. donok
    donok Every Little Helps .....
    16 Feb 2011
    I would get
    Msi p67 mobo
    Gtx 580
    8gb ram
    256gb crucial m4 SSD
    1-2tb storage HDD
    Dell u2412m
