Build Advice New PC Required for Skyrim/Diablo 3
Discussion in 'Hardware' started by Wiegold1976, 5 May 2012.
  1. Wiegold1976
    Wiegold1976 What's a Dremel?
    5 May 2012
    Hi All,
    Its been a while since I have used these forums, but again I find myself in need of some expert advice. :rock: My last PC was given to my son so now I'm PC-less with imminent release of Diablo 3:clap:. Gaming will be the main purpose of the system, but I would like to be able to play more demanding games such as Skyrim on max without any issues. The 7850 cards appeal, but not sure how this would hold up with the monitor selection below.
    A complete system is required including monitor. The Dell ultrasharp U2412M looks decent so I have based my resolution on this panel (Although this is in no way fixed).
    I Live in the UK so all parts must be available for delivery and please use sterling as currency :thumb:
    I do have a 650w seasonic PSU and 1TB HDDs that may be useful (but they are SATA II).
    Budget: £800-£1000
    Main uses of intended build: Gaming (Diablo 3, Skyrim, COD)
    Parts required: Complete system including monitor
    Previous build information: 650w Seasonic PSU, Various 1TB HDDs
    Monitor resolution: 1920x1200
    Storage requirements: Possible SSD, I have some 1TB Sata II drives for storage if usable.
    Will you be overclocking: no
    Any motherboard requirements: USB 3.0 Header for case
    Extra information about desired system:
    Thanks for you help in advance.
    If you require any further information then please let me know.
  2. MrTeal
    MrTeal Minimodder
    27 Aug 2010
    Yes reuse your 1TB HDDs, mechanical harddrives barely saturate the SATA 1.5Gb/s (SATA I) spec, so it's definitely not a disadvantage that they are not SATA 6Gb/s.
    Intel i5-2400 3.1GHz £144
    http://www.ebuyer.com/search?limit=50&store=2&cat=22&filtersubcat=3333|3519&sort=pricelow&page=1
    MSI Z77A-G45 £95
    www.dabs.com/products/msi-z77a-g45-s1155-intel-z77-ddr3-atx-80KQ.html
    Crucial 8GB (2x4GB) DDR3 1600Mhz Ballistix Sport Memory Kit CL9 (9-9-9-24) 1.5V BLS2CP4G3D1609DS1S00CEU £35
    http://www.ebuyer.com/342352-crucia...ort-memory-kit-cl10-1-5v-bls2cp4g3d1609ds1s00
    SAPPHIRE HD 7870 2GB GHz Edition £250
    www.dabs.com/products/sapphire-technology-ati-radeon-7870-1000mhz-2gb-pci-express-3-0-hdmi-80T7.html
    Antec Three Hundred Two £55
    http://www.ebuyer.com/341398-three-hundred-two-tower-case-incl-usb3-0-connector-in-0-761345-15320-1
    Or whatever other case you like.
    Samsung SSD 830 series 128GB Basic kit/bare drive £115
    www.dabs.com/products/samsung-128gb-830-series-sata-6gb-s-2-5--ssd-basic-kit-819N.html
    There is also a destkop upgrade kit available, more expensive, which comes with Norton Ghost software, a SATA cable and an adapter to install it into a 3.5" drive bay.
    Windows 7 Home Premium 64bit SP1 £65
    http://www.ebuyer.com/259863-microsoft-windows-7-home-premium-w-sp1-licence-and-media-1-gfc-02050
    Total: £744
    Dell Ultrasharp U2412M £218
    http://www.amazon.co.uk/Dell-Ultrasharp-U2412M-Widescreen-Monitor/dp/B005LNDPPS
    Total: £962
    I haven't included peripherals because I didn't know if you wanted them included in the budget or not and I'm not one for recommending them anyway because they are personal choice items, but if they are to be included then you still have space left in the budget.
  3. narwen
    narwen narwen
    6 Aug 2010
  4. GregTheRotter
    GregTheRotter Minimodder
    9 Aug 2008
    128gb ssd's can be had new for cheaper now. £90-100.
  5. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    Graphics-wise, Skyrim is fine on my 6870 at 1080p. I'm playing with everything maxed except AA, which is set to 2x. I'd say a 7850 is probably about perfect, as you can get one for under £200.
    Then go Ivy Bridge i5 and get a decent cooler for it to give you some overclocking headroom.
  6. adam_bagpuss
    24 Apr 2009
    diablo is not difficult to run at all. Skyrim though i manage high settings and get around 40-50FPS with some dips down to the 30's when it gets tense.
    in the D3 beta i maxed it @ 1920x1080 and had no issues.
    i7 920@ 3.8Ghz with 6 GB of 1600mhz + 1GB 4870.
  7. Wiegold1976
    5 May 2012
    Thanks for the help :)
    I have purchased some components (enough to get me started with the odds and ends I have lying about)
    I went for i5-3570k, Asus P8Z77-V LX, 8gb Corsair Vengeance, 128gb Crucial M4 SSD and an Antec one case.
    Still need GPU and monitor so will probably go with 7850/7870 and the Dell U2412M.
    Thanks again :)
