I've been trying to run some benchmarks, so I can update my entries in the 3DMark06 thread, and I can't seem to get it to display the results on screen like everyone else can. I get this.... Others are using the basic edition also, and can get offline results, but I can't. What gives?
Look for an older edition, i too remember when it used to show up without going online But that was in the pre 1.1.0 version that everyones using, try doing a search in the archives of some filesharing sites to find it
Try the upgrade patch http://downloads.guru3d.com/3DMark-06-v1.10-June-09-upgrade-patch-download-2293.html
Sorted. It's the newer versions... just a way to make you part company with $19. I installed 1.02 instead.
