News Zalman Reserator 3 pictured ahead of CES
Discussion in 'Article Discussion' started by Gareth Halfacree, 21 Nov 2012.
  1. Gareth Halfacree
    4 Dec 2007
  2. TheStockBroker
    TheStockBroker Modder
    19 Nov 2009
    400w....
    That's not even possible?
  3. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    Why?
    (Not an attack, just interested to see why you think it can't dissipate that kind of heat)
  4. Marvin-HHGTTG
    Marvin-HHGTTG CTRL + SHIFT + ESC
    10 Oct 2010
    400W is possible, but it depends upon the Delta-T they've chosen. If it's 400W at 50°C delta T with 2000rpm, then it's not impressive at all. It does also depend upon the flow rate.
    Check the graphs at the bottom of this page for how "proper" 120x3 radiators do with a 10°C delta T and the watts dissipated. The flow rates are probably higher in these examples too, so the 0.4GPM graph is probably most representative. What can be seen is that 120x3 radiators at that flow rate get about 350-400W dissipated at 2000rpm. Assuming that a 120x3 performs 3 times better than a single 120 (which it probably doesn't quite), then Zalman are looking at a pretty large Delta T for 400W...
  5. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    Well it certainly looks good. I wonder if the will bring out a 120x2 version and then all we need is price.
  6. lacuna
    lacuna Minimodder
    9 Aug 2004
    My original reserator is still working fine cooling a 3.00ghz P4 and 7950GT (AGP). Its actually been connected for more than 5 years now and I haven't opened it up since fitting it. Thats pretty impressive reliability I think.
  7. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
    I think it's mad for Zalman to continue the Reserator moniker given how poor their previous XT model performed. The sticking flow rate indicators that would throw the system into an alarm was hopeless, even after replacing the part, mine still had problems. I have to switch mine to manual upon booting up as auto would cause the fan and flow rate to drop to alarm inducing speeds. Even after a de-gunking and fresh coolant.
    Hopefully these prove to be more reliable. Their fanless Reserator 2 was excellent (it cooled a Pentium D 945 @ 4ghz + 8800GTX just nicely) and I've only just recently passed it on to a friend.
    Any clue as to what coolant will be used? as their blue additive gunked up worse than Porkin's home furnishings. ;)
    Edit: shame no 775 socket support :(
  8. Shirty
    18 Apr 1982
    I have a Reserator 1 V2 in sat in my cupboard doing nothing, but it happily cooled my old GTX580 heavily OC'd. Is this the sort of thing that people still want to own? The thing with Zalman is that their engineering is usually epic, but the products themselves are often a let down.
  9. dyzophoria
    dyzophoria Minimodder
    3 May 2004
    that's one sexy cooling system
  10. gcwebbyuk
    gcwebbyuk Dib Dabbler
    16 Feb 2010
  11. Dave Lister
    Dave Lister Minimodder
    1 Sep 2009
  12. MrGumby
    MrGumby CPC 464 User
    27 Apr 2009
    It's interesting that they don't use water like regular water cooling systems !
    I lol'd
  13. Snips
    Snips I can do dat, giz a job
    14 Sep 2010
    I think it looks ace but I have been known to pick up the occasional bint.
  14. ChaosDefinesOrder
    ChaosDefinesOrder Vapourmodder
    6 Feb 2008
    Personally, I think the interesting thing here is that the radiator assembly /appears/ to fit completely into the footprint of a 120 fan. For people with 120 fan mounts that are recessed in some way preventing the installation of standard 120 radiators, this is an improvement!
    I only wish it came in a red LED variant...
  15. xxxsonic1971
    xxxsonic1971 W.O.T xxxsonic1971
    5 Dec 2010
    The water in this is wetter i wonder??
  16. lilgoth89
    lilgoth89 Captin Calliope
    12 Mar 2011
    i wonder if this could be compatible with GPU units ( like the h70 was with custom plates ) id love to see a proper gpu cooling setup similar to the artic cooling one ( albeit without the insane price cost )
  17. Guest-16
    Guest-16 Guest
    I hate to think what's grown inside :eeek::eeek::eeek:
    Wasn't the whole point of the reserators that they were external? I gotta admit the originals were a piece of art to have sitting on your desk/floor.
    I ran one for a while waaay back maybe 10 years ago. The blocks were pants but the res/rad/pump was pretty pimp.
  18. docodine
    docodine killed a guy once
    10 Feb 2007
    it's nice that they've put their on twist on the CLC concept, you can tell just by looking at it that it's a zalman based on the shape of the fins
    otherwise THIS IS NOT A RESORATOR, why couldn't they have come up with a new name instead of tarnish a known branding with what will likely end up being a sub-par product :(
  19. lilgoth89
    12 Mar 2011
    acually the Resorator means combined radiator and reservoir...and by the look of it
    thats a combined reservoir and radiator XD
    and dont dismiss it before you see final cooling numbers..im sure the same thing was said when they demo'd the first tower coolers, the first all in one water coolers etc etc etc
  20. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    Now I can't wait to see the Bit-Tech / Custom PC tests on that!
