News Microsoft Research launches Code Hunter
Discussion in 'Article Discussion' started by Gareth Halfacree, 16 May 2014.
  1. Gareth Halfacree
    4 Dec 2007
  2. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    well I got stuck @ 1-6 so that shows how rubbish I am, lol
  3. mi1ez
    mi1ez Modder
    11 Jun 2009
    Just hit 1-06 myself. Not an easy one. I don't think I'm learning a single thing about coding though, just algebra!
  4. mi1ez
    mi1ez Modder
    11 Jun 2009
    Not sure if there even is an elegant solution to this, or if I'm supposed to just use if statements...
  5. mi1ez
    mi1ez Modder
    11 Jun 2009
    Got it! I was thinking in real rather than int!
  6. theshadow2001
    3 May 2012
    Went through section 1 which is writing single line return statements. I found some of them tricky to find the correct pattern. Definitely nothing to do with learning code there. In fact some were just infuriating .
    Section two is about loops so that's where things take off a bit. Did the first one with a C style for loop, then I tried a foreach loop, I finally got it down to an array declaration a while loop with 1 line of code and a return for the array and still I only get 1 out of 3 score. :'(
    Anyway its definitely not fun, but I think they are on to something on interactive coding exercises. I'm just not sure the approach they have taken is any good. Its also quite slow at times
  7. kHAn_au
    kHAn_au What's a Dremel?
    12 Dec 2005
    Definitely some of the best implemented coding CBT I've tried....
    I agree figuring out the sequences in section 1 is annoying.
