Other I3-2100 8gb RAM - ESXi ? 4 virtual machines
Discussion in 'Software' started by happysack, 14 Jan 2012.
  1. happysack
    happysack goodateverthinger
    19 Dec 2009
    Would this work? Not looking for high spec but it should run
    1 x win7 2gb
    1 x unbunto 2gb
    1 x mac os x 2gb
    1 x server 2k8r2 4gb
    anyone shed some light?
    Regards
  2. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    - removed, because I was wrong :)
  3. saspro
    saspro IT monkey
    23 Apr 2009
    Technically it'd run.
    You have over provisioned on the RAM but ESXi can deal with that. You may get some slowdowns due to memory swapping but it will run.
    Just make sure your NIC is on the HCL
  4. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    What saspro said, and just remember that ESXi is baremetal so you'll have to access those guests remotely. If you want four different desktop operating systems you'd need VMware Workstation or VirtualBox.
    You probably already know this, but I wanted to be sure as not everyone realises!
  5. Shabing
    Shabing What's a Dremel?
    27 Nov 2008
    i3's don't have Vtx either: dunno if Esxi needs it or not, but its one thing to consider.
  6. Shabing
    27 Nov 2008
    Ignore me, they do.
  7. happysack
    19 Dec 2009
    Yeh have a pc to access it remotely on.
    Used it a little bit but just wanted more exp on it. Also idea for lab at home.
    Regards
