Motherboards 1366
Discussion in 'Hardware' started by xxxsonic1971, 3 Nov 2011.
  1. xxxsonic1971
    xxxsonic1971 W.O.T xxxsonic1971
    5 Dec 2010
    hello all,
    is intel x58 still the best, as i can get a cheap 990x (£300) to upgrade my i7.
    any thoughts welcome
    many thanks
    xxxsonic
  2. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    Essentially no not really, although a 990x is an amazing chip, i5 2500k and i7 2600k/2700k beat or draw level with the 990x at most things apart from heavily multi threaded applications, so if thats what your using your pc for then the 990x might be a good idea, if not I'd say change to sandy bridge setup, but also Remember Sandy Bridge-E or lga 2011 is roughly two weeks away and should be pretty darn good :D
  3. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Yeah don't put £300 into an aging platform. I spent £300ish on a 6-core/12-thread CPU for my system and whilst it is nice, it really doesn't make any difference at all unless you are doing something that requires the extra threads or if you do DICE/LN2 benching and would appreciate the unlocked multi etc.
    I benched the royal fook out of my 970 and then sold it on a few days later. :D
  4. GoodBytes
    20 Jan 2007
    x58 is a great platform.. IF you have it already.
    Sandy Bridge is just a bit faster... it's more efficient then anything else. But buying x58 now, is silly.
  5. Arghnews
    Arghnews What's a Dremel?
    6 Jul 2011
    Agreed with above. The I7920 is very capable, and unless you need the serious performance, don't bother.
    Why are you upgrading, then, may I ask? Or just asking because you had an opportunity to get a cheap 990x ? :D Which is fair enough
  6. debs3759
    debs3759 Was that a warranty I just broke?
    10 Oct 2011
    If you can afford an i7 990X, then waiting a couple of weeks and getting a 3930K (or evn 3960X if your budget is high enough!) will get you a better performance. Performancewise, 3930K is scaled against 980X and 3960X is scaled against 990X, and the SB-E will perform better at most tasks. Both are already available for pre-order in the USA, although the cheaper, multiplier locked processor appears to have been delayed (not sure why the worse performing chip is delayed and the extreme chips are on schedule!).
  7. brave758
    brave758 Minimodder
    16 Apr 2009
    mate go for it its a good long term upgrade for your system, as long as you haven't got the upgrade bug is will do you for a good few years (this only applies if you have a 1366 i7 system)
  8. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    No, just no. How is it a good upgrade? On a gaming machine it'll make little or not difference having those extra cores. Just overclock the 920, it'll get to a similar point that the 990X would on air cooling.
  9. David
    7 Apr 2009
    Buy the 990 for £300 and flog it for a profit on ebay. Then, buy Sandy Bridge or newer.
  10. Ljs
    Ljs Modder
    4 Sep 2009
    ^This!
  11. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Yeh he should definitel OC his 920 to 4GHz. I had my 970 @ 4.5GHz HTon / 4.6GHz HT off and really didn't notice much difference at all - yes it was nice, but not "worth £300" nice. :D
  12. TheKrumpet
    TheKrumpet Once more, into the breach!
    18 Oct 2011
    The 920 is a doddle to get running at 4GHz on air, that would be my recommendation too. I may actually have to think about sticking mine back up, Comp's starting to feel sluggish...
  13. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Hell at that price I still would take if I was you but that os if you have the mobo and everything else that goes with a1366.
    Sent from my GT-I9000
  14. bulldogjeff
    2 Mar 2010
    At that price if your not planning an upgrade for another couple of years then grab hold of it, I can't see programing or games moving on so far in the next few years that it wouldn't be able to cope with anything thats throw at it.
  15. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    As far as upgrades go, IMO he'd be much better spending £300 on a new GPU and an SSD, or a nice monitor.
    CPU upgrades should be FAR down the list if you already have a hyperthreaded quad...
  16. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    See as someone said above I would buy and sell it again on eBay you will get at least £100 profit
  17. xxxsonic1971
    5 Dec 2010
    the deal is done! as soon as my mate gets his new x79, gulftown six core magic is all mine!!!
