Quiet Desktop Case
Discussion in 'bit-tech Folding Team' started by slambittech, 10 May 2014.
  1. slambittech
    slambittech Minimodder
    17 Oct 2009
    Hi All,
    Can someone recommend a really quiet case with my desktop spec, its abit old so its getting really loud and so I want a case that is sound proof.
    Was looking at the NZXT H2 Classic Silent Midi Tower Case which is £80. Looking for anything cheaper, not too worried by the looks.
    Any recommendations?
    Also is the NZXT H2 Classic Silent Midi Tower Case any good?
    Thanks
  2. johnim40
    johnim40 Minimodder
    23 Apr 2009
  3. slambittech
    17 Oct 2009
  4. Petaflops
    Petaflops Minimodder
    27 Aug 2013
    Hi.
    I went for a Corsair Obsidian 550D for my new PC. This has sound deadening materials inside which makes the PC very quiet when it isn't folding. However when the 2 x GTX770 are on full with the fans at 100% to keep everything cool, the case becomes a bit irrelevant! I probably should have bought the cheapest, tinniest box available. Have you hoovered out all the filters and fans on your existing machine. It's amazing how much dust builds up in a machine and how it adds to the noise of fans etc. Pete
  5. johnim40
    johnim40 Minimodder
    23 Apr 2009
    hi i have the 750d and im fed up of cleaning the filters on it with my 2 660s folding 24/7 in the living room but noise wise quiet
  6. DocJonz
    DocJonz Another CPC refugee .....
    24 Apr 2009
    I usually have to clean PC filters once or twice a month on all Folding machines, as well as giving the insides a few blasts with some dust-off!
